2000 Caravan Alarm/Remote Start
kayos592
Posted: January 20, 2005 at 9:03 PM / IP Logged
Hey guys... I must admit there are some intimidating terms in some of these posts. I just purchased an alarm/remote start for my 2000 Dodge Grand Caravan. It has a black key and currently has no security on it at all. I have never installed a remote or alarm but feel that I can do it if only I had the right guidance....and there definately seems to be a plethora of knowledge in this forum.
Ok, so.... I have the basics understood...the plugs for the sensor, switch, receiver, l.e.d. are all simple enough.
I also have the wiring diagrams for my car.
I am pretty confident about the starter, Ignition1 and ignition2, and acc connections.
My remote start comes with computer with all the wiring details on it's bottom. so is it as simple as using a wiring diagram to locate a wire (ie. brakelight switch) and connecting my corresponding colored wire?
I really want to learn this as I feel it's a valuable skill to have.
Any help is greatly appreciated.....Also, I'm in Queens, NY so if anyone would like to teach me I would be willing to pay.
The alarm I'm using is Magnum Alarm/Remote Start. These are the specs on the alarm....
Features:
-Works on diesels.
-Built-In Start Relays,Accessories,Ignition,Starter Outputs.
-Tach-Less System.
-Built-In Dual Zone Shock Sensor with "SHOCK TECH" Technology, Adjustable Via Remotes.
-Door Locks & Parking lights Built-In Relays.
-Smart Passive/Active Adjustable.
-Passive Lock/Unlock.
-Panic mode.
-Multi-Tone Loud Siren.
-Super Bright Red LED Light.
-Multi function Valet Switch.
-Full Keyless Entry in Valet Mode.
-Ignition Triggered Doorlocks with Open Door Auto Cancel.
-Smart Channel-2 Output, Features Auto Disarm.
-Advanced Fault Tolerant Outputs.
-Multiplexed PATS, VATS and Factor Alarm Disarm Outputs.
-Smart Passive Locking Feature. The system will never lock your keys in the car.
-MemoMax(TM) Feature
-Dome Light Supervision.
-Full Security During Remote Run Can be Armed While Running & Can Be Started While Armed.
-Retries Automatically Up-to 4 Times If The Engine Fails to Starts.
-Smart Design (Stable, Small & Reliable) For Fast Installation.
-trunk release.
-long range antenna up to 2000 feet!
-Hood Switch- prevents the engine from starting while the hood is open. Brake Pedal disable.
-Anti-Theft Feature -protects your vehicle by automatically shutting the engine down if it is tampered with.
Thank You,
Kay
Platinum - Posts: 12,488
Posted: January 20, 2005 at 11:07 PM / IP Logged
Sounds like you have a good grasp on the installation already. The only thing that is a concern for this vehicle would be the door locks as it requires relays and resistors because it's a type F ( single wire system ). The other thing is that you do not need to connect the ACC wire as it's not necessary to hook up for this vehicle.
You can use the (-) parking light wire found at the switch. I just did one today in about 1.3 hours and it very easy as it doesn't have the Sentry key or the 2nd starter wire.
kayos592
Posted: January 21, 2005 at 2:23 PM / IP Logged
Jeff,
Thanks so much for the confidence boost. Ok, So am I right in simply identifying the different color wires using the wire color guide a site like this offers, then match them with the Remote Start Base.
Now you said I need relays and resistors because it's a type F(single wife system).  So can i goto Radio Shack and just ask for relays or are there specific relays that I would need. Also, any specific resistors? Man I wish you were in NY so you could help me...lol.
-Kay
forbidden
Platinum - Posts: 5,354
Posted: January 21, 2005 at 9:57 PM / IP Logged
You need a SPDT type relay, Bosch and Hella make good relays. Any car audio shop would have them as well. I just did a 99 Caravan today and mine took a little longer than Jeff as I was the only one here and kept getting pulled off of it. The locks will be a little tricky for you. IIRC you will need a 1500ohm and 250 ohm resistor. Tie the ends of the resistors together on one end only. That end is the end that you should connect to a extension line (green if possible to match wire colors) that will tie into the single wire lock / unlock system. The wire is found behind and under the fuse box. You will see two really large plugs about 2" x 3", white in color on the outside. The first one is easy to unplug, it may have a small red retainer that must be pulled down first and the the molex can be released and pulled down out of the way. The second moles is easier removed if you pull the carpet out of the way, gently pull the fuse box towards the seat and then unplug th emolex. This molex should be a grey colour and you will need to strip away the black tape and hockey tape around all the wiring. Locate the white with dark green stripe wire, this should be the lock/unlock wire and tie the wire with the resistors to it. Solder this wire on if possible.
The other side of the resistors need to be kept separate from each other. Attach a blue wire to one and a black to the other (or whatever color wire you have). Take your two relays and black tape them together side by side. Take one wire and attach it to pin 30, take the other wire and do the same on the other relay. Take your two wires from the brain that are the lock and unlock and attach them to the appropriate relay on pin 86. Each relay now needs a +12v and ground connection. Ground pin 87 on each relay. Apply +12volts constant to pins 85 on each relay. The power wires must be protected with a 10amp fuse. Attach this wire with one of the constant power lines from the remote starter where you attach it to the vehicle wiring.
Power locks  = done like dinner.
This vehicle also has a negative park light circuit. You need to find out if your remote start / alarm has a neg park light output. If it does not then you will need a 3rd relay of the same type and we can go through it's wiring later.
kayos592
Posted: January 22, 2005 at 9:34 PM / IP Logged
Man, I wish you had this with pictures...lol... it's like... i think i am imagining what your saying....but WHAT IF I'M WRONG?????....lol. DOes anyone know a place online that would give a step by step picture by picture instructions for this vehicle? If not, (and if any of you have access) I'll be willing to pay for such information. Also, I'm a programmer so if someone wanted to sell this type of information I would be glad to help with the site creation to make this skill make even MORE money for you....
IF anyone is interested please let me know.... in the meantime Rob.... please let me know if you know of a site which can confirm my "visions"....
-Kay
P.S. -- I really want to do this.... I just need guidance....
johnnydi77
Copper - Posts: 54
Posted: January 23, 2005 at 8:53 AM / IP Logged
First of all you can eliminate the resistors and go straight to the door lock relays. There will be three relays, one locks, one unlocks the drivers door, and one unlocks the rest of the doors. Pull the relays out and wrap an wire around pin 85 of each and your done. Negative trigger door locks. Relays are to the left of the column. You will have diode isolate the unlock wires with 2 1 amp diodes cathode(band side) facing the alarm/starter.
John J. DiStefano Jr.
Keithmarsh
Posted: January 23, 2005 at 8:18 PM / IP Logged
I used that same "direct to relays" method.  Here's a link to a nice diagram for it:
http://www.designtech-intl.com/Content/techsupport/documents/section04/note155.pdf
forbidden
Posted: January 24, 2005 at 12:22 PM / IP Logged
The issue that I have with this (and probably Jeff and others as well), is that it is not a proper method of connection that is basically a ghetto way of doing things instead of the proper way of doing things. While it may work, in time the wire may fail and short something out as it is not a permanent connection and the vehicle is always prone to vibration and bumps. Do it right guys, it does not take that long. I as a retailer will do things the correct way to minimize any chance of failure and to ensure that the customer is happy.
