2000 Sienna remote starter installation
Acfrqflyer
Posted: January 21, 2005 at 1:45 PM / IP Logged
Does anyone know where i can get the wire info to install remote starter w/keyless entry for a 2000 toyota sienna??
Also my remote starter has only 1 ignition wire and the 2000 sienna has 2 ignition wires. How do I connect both to a relay???
AC
mo12v
Posted: January 21, 2005 at 3:32 PM / IP Logged
Constant 12 voltsWHITE/ RED & WHITE/ BLUEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterREDIGNITION SWITCH HARNESS
Dome LightRED / WHITE (-)7 PIN CONNECTOR AT FUSE BLOCK
Trunk Pin SwitchNA
Parking LampGREEN (+)BLACK 6 PIN CONNECTOR AT FUSE BLOCK
Power LockL GREEN **7 PIN CONNECTOR *
Power UnlockBLUE/REDIN DRIVER KICK PANEL
Child Safety Locks
. * Child Safety Lock - BROWN / RED (-) In 12 Pin Connector In Driver Kick Panel. ** Lock Wire At Integration Relay Can Be Found As BLUE/WHITE, Unlock Wire At Integration Relay Can Be Found As BLUE / YELLOW
Accessories
Window UpD\ GREEN P\ GREEN / WHITE @ MAIN SWITCH
Window DownR/ RED S/ RED / BLUE
Ign Key WarnBLUE/BLACK (-)5 PIN CONNECTOR AT FUSE BLOCK
Trunk ReleaseN/A
OEM HornGREEN/ BLACK (-)STEERING COLUMN HARNESS
HeadlightsRED / GREEN (-)AT HEADLIGHT SWITCH
OEM Alarm ArmBLUE/WHITE (-)7 PIN CONNECTOR IN DRIVER KICK PANEL
OEM Alarm DisarmBLUE (-)12 PIN CONNECTOR IN DRIVER KICK PANEL
 Reversal Rest At Ground Power Window Circuit
POWER SLIDE DOOR - (-) GREEN/ YELLOW Wire On Top Of Radio Will Open/Close Easy To Locate Just Remove Panel On Top Of Radio To See Wire.
Remote Start
Tach SignalVIOLET/REDAT ENGINE CONTROL MODULE *
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLUEIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightRED / BLACK (+)13 PIN GRAY CONN. IN PASS. KICK PANEL
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* Engine Control Module Is Located In Passenger Kick Panel.
Immobilizer BYPASS
Do you have "Negative Output while Running" wire?
MO
Acfrqflyer
Posted: January 22, 2005 at 10:30 AM / IP Logged
what do you mean by "Negative output while running" wire?? which wire/??
Thursday, October 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
