Installed Alarm - No Turn Signals
65Mustangs
Posted: January 25, 2005 at 3:21 PM / IP Logged
Installed an alarm and keyless into a '89 Jeep Cherokee, when completed turn signals no longer worked. There are two blue wires going into the headlamp switch, used one for running lights flash, when alarm armed. Any ideas how to troubleshoot turn signals? Need info on wiring to troubleshoot. I think either a relay got shorted out, or something was left disconnected, but am unfamilier with turn signal wiring. Please Help!
TJ92Civic
Copper - Posts: 161
Posted: January 25, 2005 at 3:39 PM / IP Logged
PARKING LIGHTS +blue/reddr. kick panel
Thats what I found for parking lights.  Check the fuses to make sure they are not blown.
tim
kgerry
Platinum - Posts: 3,455
Posted: January 25, 2005 at 3:43 PM / IP Logged
also check to make sure the hazard switch isnt halfway between on and off.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
kidtransam
Copper - Posts: 99
Posted: January 25, 2005 at 6:51 PM / IP Logged
a quick test would be to unplug the alarm brain and see if the turn signals work. if they do, its in the wiring of your alarm..if not..you have blown a fuse or disconnected something.
With a torch and a big enough hammer...it WILL friggin fit!!
Javelin3o4
Copper - Posts: 239
Posted: January 28, 2005 at 1:07 AM / IP Logged
i was gonna also suggest checking the hazard switch cause on most cars the turn signals are wired through the hazard switch and if its unplugged the signals dont work, so try hitting the hazard button and see if the work.
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
