1995 4x4 S10 Blazer Power Window wiring
CBill
Member - Posts: 28
Posted: January 26, 2005 at 12:35 PM / IP Logged
Anyone have a wiring diagram for a 1995 4x4 S10 Blazer 4 doors Power Windows?
I am getting ready to install a power windows module for all 4 windows and am looking for a wiring diagram along the location of the wires ..
I suspect the wires are all in the driver kick panel but I would like to check to make sure that the wires are connected directly to the windows power motor at each door because from the intruction of the power windows module it need to be in a direct contact with the windows motor   .. I believe so it can detect the current load when the windows is completely rolled up or down and stop the current to the windows motors ..
If anyone installed one before  can you tell me if I need to get around to the built in factory auto windows roll down which is found on driver side that you press just once and it'll roll all the way down for you .. Will that be an issue for me when I go install the modules?
Bill
itmdtr
Copper - Posts: 131
Posted: January 26, 2005 at 7:34 PM / IP Logged
I installed a module on my 89 S-10 blazer. It didn't have auto down, but I'm pretty sure you have to go into each door (4 in your case) between the switch and motor. The module I installed was a 530T from DEI.
itmdtr
CBill
Member - Posts: 28
Posted: January 27, 2005 at 6:59 AM / IP Logged
I found a wiring diagram last night at the local library .. The way it look like it set up that you can wire them all up on the driver master switch and the switches at the each door is acting like a bridge directly to the motor until you press up or down on it .. I think I got it now .. I hope hehehe
Wish me luck!
Bill
CBill
Member - Posts: 28
Posted: January 27, 2005 at 4:42 PM / IP Logged
The local library diagram didn't even match my Blazer and I think it beause my Blazer is a "LT" with auto windows down and door handle dome light supervisor built into the master console ...
Anyway I took all my door panels apart and traced all the wiring .. so here it is for anyone who may need the power windows wiring diagram for a 1995 4x4 "LT" S10 Blazer
Here the wiring diagram ..
LF - UP - Blue - 8pin connector "A"
LF - DOWN - Brown - 8pin connector "E"
RF - UP - Light Blue - 8pin connector "B"
RF - DOWN - Tan - 8pin connector "D"
LR - UP - Green - 8pin connector "G"
LR - DOWN - Purple - 11pin connector "K"
RR - UP - Light Green - 8pin connector "H"
RR- DOWN - Purple - 11pin connector "H"
Each of the connectors under the console have letters marked for each wires that goes into it .. RL and LR both have purple wire for DOWN but it *not* the same purple wire ..
Bill
CBill
Member - Posts: 28
Posted: January 27, 2005 at 4:44 PM / IP Logged
Well I can't see to edit my own posts on this forum so anyway I forgot to mention that the connectors are the ones that plugs into the master power windows console on the driver side ..
Bill
