2004 Acoord wiring diagram
achadwick23
Member - Posts: 9
Posted: January 28, 2005 at 12:15 PM / IP Logged
Can anyone help me? i need a wiring diagram for a 2004 Honda Accord LX 4-door?
jaurora
Silver - Posts: 429
Posted: January 28, 2005 at 12:26 PM / IP Logged
Honda
Accord
2003-2005
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/ White
Ignition Switch Harness
Ignition #1:
BLACK / YELLOW
Ignition Switch Harness*
Ignition #2:
BLACK/ Red
Ignition #3:
N/A
Accessory:
WHITE/ Red
Brake Light:
WHITE/ Black
At Brake Switch
Tach Signal:
Blue/Red or Blue
On ECM/PCM in front of the transmission tunnel.
Parking Lights:
RED / Black
Large white plug above fusebox
Headlights:
No Color Available
Please call with info
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
No Color Available
Notes:
* This vehicle has a transponder anti-theft system.
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
White
OEM Alarm Disarm:
White (-)
In drivers door module in door
Dome Lights/Superv:
GREEN/ Red
Behind Fuse Box
OEM Horn:
GREEN/ YELLOW
Steering Column Harness
Power Lock:
Pink/Black
Green plug left side of fuse box***
Power Unlock:
Pink/Blue
Trunk Release:
YELLOW /GREEN (+)
Drivers kick panel harness
Alarm Input Wire:
GREEN/ Red
Behind Fuse Box
Notes:
*** The door lock wires must be tested from the passenger switch.
MECP certified (If it really means anything)
Jeremy
achadwick23
Member - Posts: 9
Posted: January 28, 2005 at 12:36 PM / IP Logged
wow thanks....that was fast! can i use the dei 555H to do the transponder by pass?
jaurora
Silver - Posts: 429
Posted: January 28, 2005 at 12:37 PM / IP Logged
I am not to sure on that bypass. I have always used the 555U. Check it out on the net.
Jeremy
achadwick23
Member - Posts: 9
Posted: January 28, 2005 at 12:41 PM / IP Logged
im been lookin everywhere...just for the wiring diagram....the disk i have only goes to 2002 i cant find any of the new cars diagrams
