acura CL security module location
profuse007
Gold - Posts: 2,015
Posted: January 28, 2005 at 4:42 PM / IP Logged
am having trouble finding the security module for this 01 CL 3.2 type-S. diff techsheet says its under the passenger seat but i dont see anything modules besides the powerseat module. i lifted the seat up to check on this, btw.
anyone help me locate this module would be great.
BTW, this is for RS-addon. everything is fine but of course i cant use the rmote after RS.
Houston,TX
mo12v
Posted: January 28, 2005 at 5:20 PM / IP Logged
RKE ModuleBUILT INTO PASSENGER MULTIPLEX CONTROL UNIT
Motor LockWHITE/ RED24 PIN BLUE CONN. BEHIND PASS DASH *
Motor UnlockLIGHT GREEN/ RED24 PIN BLUE CONN. BEHIND PASS DASH *
Drv Door UnlockYELLOWAT DRIVER SIDE FUSE RELAY BOX
OEM RelaysBUILT INTO PASSENGER MULTIPLEX CONTROL UNIT BEHIND GLOVE BOX
MO
profuse007
Gold - Posts: 2,015
Posted: January 28, 2005 at 5:41 PM / IP Logged
thanks MO
Houston,TX
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
