2004 Chevy Impala, diode isolate parking lights
Uniqueauto
Copper - Posts: 73
Posted: February 02, 2005 at 8:07 AM / IP Logged
How exactly do you diode isolate the parking lights from the BCM?
thepencil
Gold - Posts: 1,526
Posted: February 02, 2005 at 8:40 AM / IP Logged
1600.pdf
This is quicker and easier.
Parking Lights + yellow (F), BROWN / white (R) +   passenger junction block end of dash
Be careful whose advice you buy, but be patient with those who supply it.2004 Chevy Impala, diode isolate parking lights  -- posted image.
mxxmikexx
Silver - Posts: 796
Posted: February 02, 2005 at 3:03 PM / IP Logged
you can save yourself the trouble of running a wire to the pass. side of the dash, by simply cutting the white wire coming out of the BCM, pink plug, pin A2. and placing a diode inline with that wire cathode (stripe side of diode) side facing the ecm plug, and tag your neg. trigger parking light from your source to the anode side of the diode. and your done, no need to run wire to pass. side of car. just did one yesterday actually.
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
NowYaKnow
Gold - Posts: 1,217
Posted: February 02, 2005 at 6:09 PM / IP Logged
Or you could just hit the blue (-) wire at the switch and be done with it. No cutting, relays, diodes, resistors needed.
Mike
mxxmikexx
Silver - Posts: 796
Posted: February 02, 2005 at 8:23 PM / IP Logged
blue (-) at switch? interesting to know.. i do quite alot of these vehicles, that could come in handy
Mike Battaglia
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
