ford transponder
tarasdad
Member - Posts: 19
Posted: February 10, 2005 at 2:12 PM / IP Logged
hi, can anyone tell me which transponder bypass i need for an 03 f-150?(pk)  Im trying not to use the dei unit. Thanks in advance, this sight is the bomb!
Platinum - Posts: 12,488
Posted: February 10, 2005 at 2:41 PM / IP Logged
Use thePKF1 no key required module. Super easy to install and to programm.
thepencil
Gold - Posts: 1,526
Posted: February 10, 2005 at 2:49 PM / IP Logged
Transponder
Ford F150 2003
Available Model(s):
PKF1 - Ford/Mazda Transponder Interface: PATS1
Data Transponder Interface: Override OEM PATS Immobilizer Via Data (No Key Required).
*Notes:
Programming Key Requirements:   1 keys required for programming purposes
Key Requirements:
Functions:
(What is it?)
TBK-ALL - Universal Tranponder Bypass Kit with All Flexi-Loops
TBK-ALL is a 4th generation Universal Transponder Bypass Kit (Ignition Key Required), designed to temporarily bypass most OEM transponder type ignition immobilizer systems when remote starting.
Programming Key Requirements:   0 keys required for programming purposes
Key Requirements:
Functions:
(What is it?)
TBKIII - Universal Transponder Bypass w/relayed (+/-) Keysense
TBKIII is a 3rd generation Universal Transponder Bypass Kit (Ignition Key Required), designed to temporarily bypass most OEM transponder type ignition immobilizer systems when remote starting.
*Notes:
Key Requirements:
Functions:
(What is it?)
TBKIV - Universal Transponder Bypass w/relayed (+/-) Keysense
TBKIV is a 4th generation Universal Transponder Bypass Kit (Ignition Key Required), designed to temporarily bypass most OEM transponder type ignition immobilizer systems when remote starting.
*Notes:
Key Requirements:
Functions:
(What is it?)
TBKIV-L - Universal Tranponder Bypass Kit with Large Flexi-Loop
Key Requirements:
Functions:
(What is it?)
TBKIV-M - Universal Tranponder Bypass Kit with Medium Flexi-Loop
Key Requirements:
Be careful whose advice you buy, but be patient with those who supply it.ford transponder -- posted image.
