99 acura tl
mobiletoys2002
Gold - Posts: 1,050
Posted: October 31, 2002 at 12:14 PM / IP Logged
i need to disarm the factory alarm upon remote start because everytime i remote start the car the factory alarm goes off,where can i find this wire i know the factory alarm  arms on lock and disarms on unlock but i see there is a blue wire suposed to be in the door key cylinder to disarm without unlock do i have to go in the door for this??,or is there an easier way to do this? also where is the trunk release wire located ? thanks in advance
techker
Copper - Posts: 70
Posted: October 31, 2002 at 3:03 PM / IP Logged
YEAR: 1999  MAKE: Acura  MODEL: TL  STYLE:
|       ITEM          |     WIRE COLOR      |POL |       WIRE LOCATION        |
|                 12V |white                | +  |ignition harness            |
|             STARTER |BLACK/ white          | +  |ignition harness            |
|            IGNITION |BLACK / YELLOW         | +  |ignition harness            |
|           ACCESSORY |yellow               | +  |ignition harness            |
|          POWER LOCK |BLACK/ blue           | -  |passenger fuse box *1       |
|        POWER UNLOCK |orange               | -  |passenger fuse box *1       |
|          LOCK MOTOR |WHITE/ red            |    |drivers fuse box *2         |
|        UNLOCK MOTOR |yellow               |    |drivers fuse box *2         |
|       DISARM DEFEAT |lt. GREEN/ red        |    |passenger MUX module *3     |
|    PARKING LIGHTS + |RED / black            |    |passenger kick panel        |
|    PARKING LIGHTS - |RED / yellow           |    |left of steering column     |
|          HEADLIGHTS |blue/red             | -  |left of steering column     |
|        DOOR TRIGGER |BLACK/ white          | -  |passenger fuse box          |
|    DOME SUPERVISION |use door trigger     |    |                            |
|     TRUNK/HATCH PIN |blue/green           | -  |drivers fuse box            |
|            HOOD PIN |yellow               | -  |passenger fuse box          |
| TRUNK/HATCH RELEASE |WHITE/ red            | +  |passenger MUX module *3     |
|   FACTORY ALARM ARM |arms with lock       |    |                            |
|FACTORY ALARM DISARM |disarms with unlock  |    |                            |
|    DISARM NO UNLOCK |blue                 | -  |drivers door key cylinder   |
|          TACHOMETER |blue                 |    |drivers shock tower *4      |
|         SPEED SENSE |                     |    |                            |
|          BRAKE WIRE |WHITE/ black          | +  |brake switch                |
|        HORN TRIGGER |lt. GREEN/ blue       | -  |steering column             |
|              WIPERS |blue & blue / YELLOW   | -  |left of steering column     |
|   LF WINDOW UP/DOWN |RED / yel - RED / blu    | A  |drivers window motor        |
|   RF WINDOW UP/DOWN |blu/wht - blu/yel    | A  |RF window switch            |
|   LR WINDOW UP/DOWN |RED / blu - RED / yel    | A  |LR window switch            |
|   RR WINDOW UP/DOWN |RED / blk - RED / yel    | A  |RR window switch            |
| SUN ROOF OPEN/CLOSE |grn/yel - grn/red    | A  |relays left of fuse box     |
|           RADIO 12V |WHITE/ green          | +  |radio                       |
|        RADIO GROUND |black                | -  |radio                       |
|        RADIO SWITCH |WHITE/ red            | +  |radio                       |
|    RADIO ILLUMINATE |RED / black            | +  |radio                       |
|       POWER ANTENNA |                     |    |                            |
|          LF SPEAKER |blu/grn - gry/blk    |    |radio                       |
|          RF SPEAKER |RED / grn - brn/blk    |    |radio                       |
|          LR SPEAKER |blu/yel - gry/wht    |    |radio                       |
|          RR SPEAKER |RED / yel - brn/wht    |    |radio                       |
techker
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
