Did I find my tach wire?
slush
Member - Posts: 38
Posted: February 21, 2005 at 7:20 PM / IP Logged
Hey,
So unsatisfied as i am with tachless, i attempted to find my tach wire.  Today i found a harness on the driver side of my 1993 mitsubishi diamante ES (WHITE/ black w/silver dots i believe)... when i unplugged the harness, I got no reading on my tachometer/fuel gage/basically anything in the instrument panel... so i thought great, i must have found it in this harness..
However after probing some of the wires going into the harness (from the source) I found one WHITE/ black wire (tach on my car is supposedly white or WHITE/ blue at the coil) which showed me something like 25V AC, and when i'd rev my engine it'd drop to like 24... 23.. etc.  I put it on DC and it was reading 12v.. dropping to 11.. 10.. etc.  Not sure if this is the wire or not.  That was the only wire (if i remember correctly) that had fluxuation on that harness when i pressed on the gas.
Anyway, I'd appreciate an input anyone has on this... thanks in advance!
-Derek
jrilla
Gold - Posts: 1,498
Posted: February 21, 2005 at 7:24 PM / IP Logged
Measure a tach source in AC volts and it typically reads between 1 and 6 volts AC. The AC volts should increase when you rev the engine.
J Rilla
Owner/Installer
slush
Member - Posts: 38
Posted: February 21, 2005 at 7:32 PM / IP Logged
actually now that i look at my dm, i was measuring at 200 on AC as that is the only option my DM has.  So that would mean i was seeing around 2.6 VAC on that suspected tach wire at idle, and upon rev i was seeing 2.5...2.4...2.3... etc.
-Derek
metaverse
Copper - Posts: 210
Posted: February 21, 2005 at 9:25 PM / IP Logged
You can always go to the instrument cluster..guaranteed tach (assuming you have a guage)
TJ92Civic
Copper - Posts: 161
Posted: February 21, 2005 at 10:39 PM / IP Logged
TACHOMETERWHITE/ blue or whiteat coil pack
Thats what I found...
tim
slush
Member - Posts: 38
Posted: February 22, 2005 at 1:51 AM / IP Logged
Well I technically did... although i didn't dig all the way up there, i found the harness that the instrument cluster uses for all of its electronics (tach/odometer/fuel gauge/engine temp/warning lights/etc.).  I pulled it out and they all didnt' work anymore.  I probed a white wire on that and saw it at 2.6 VAC while i was idle.  When I pushed down on the gas, the voltage dropped... then went back up when i released the gas pedal.  I was probing the wire with the red (+) lead and grounding the (-) lead to my chassis.
-Derek
