directed 556U for 2005 toyota corolla S
zeidouni
Member - Posts: 7
Posted: March 04, 2005 at 11:51 AM / IP Logged
I have a directed  556U unit to use to connect on a 2005 toyota corolla S.  I would really appreciate it if anyone can give me valid info on what type of connection I should use for the 556U on that speicific vehicle.  I have not opened the unit or the ignition column on the car yet.  I'm just curious whether I should wire the 556U with the basic connection or if I have to use alternate immobilizer interfeace No.1 or No.2
mxxmikexx
Silver - Posts: 796
Posted: March 04, 2005 at 12:45 PM / IP Logged
if you use it just the way it comes in the box and put the antenna ring around the key cylinder youll be all set
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
superman1218
Member - Posts: 13
Posted: March 04, 2005 at 3:24 PM / IP Logged
Hey,
  I spoke to the shop forman at my nearest dealer and he told me that Toyota uses the same immobalizer on all there toyota cars and trucks.. So you could use the 555x on your 2005.. 555x will not require a key to be given up.
superman
zeidouni
Member - Posts: 7
Posted: March 04, 2005 at 3:26 PM / IP Logged
I guess, I'm a little bit ahead, I already bought the 556u.  Thanks anyways
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
