Need wiring diagram 2001Town and Country
homey88
Member - Posts: 42
Posted: March 08, 2005 at 10:16 PM / IP Logged
I need a Alarm/RS wiring diagram, thanks in advance!
Brian
thepencil
Gold - Posts: 1,526
Posted: March 08, 2005 at 10:24 PM / IP Logged
2001 Town and Country
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|lt blue/red (10A) *1|+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|   SECOND STARTER|PURPLE / brown *12    |- |ignition harness            |
|        IGNITION|pink/white          |+ |ignition harness            |
|        ACCESSORY|*11                 |   |                            |
|       POWER LOCK|PURPLE / green *3     |- |conn. 3, pin 21 @ BCM *2    |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|tan/white           |   |conn. 2, pin 10 @ BCM *2    |
|     UNLOCK MOTOR|tan/lt. green       |   |conn. 2, pin 28 @ BCM *2    |
|    DISARM DEFEAT|tan/brown           |   |conn. 2, pin 26 @ BCM *2    |
| PARKING LIGHTS +|DO NOT USE          |   |                            |
| PARKING LIGHTS -|WHITE/ brown *8      |   |headlight switch            |
|       HEADLIGHTS|same wire           |   |                            |
|     DOOR TRIGGER|*4                  |- |BCM *2                      |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|PURPLE / orange *9    |- |conn. 3, pin 29 @ BCM *2    |
|        HOOD PIN|PURPLE / lt. blue     |- |conn. 3, pin 30 @ BCM *2    |
|TRNK/HTCH RELEASE|*10                 |   |*10                         |
| FCTRY ALARM ARM|PURPLE / lt. blue     |*5 |conn. 3, pin 14 @ BCM *2    |
|FCTRY ALRM DISARM|same wire           |   |                            |
|       TACHOMETER|*6                  |   |ignition coil pack          |
|      SPEED SENSE|blue/orange        |   |PCM *7                      |
|       BRAKE WIRE|WHITE/ tan           |+ |brake pedal switch          |
|     HORN TRIGGER|GREEN/ purple        |- |steering column             |
|           WIPERS|brn/wht & brn/org   |+ |wiper motor                 |
| LF WINDOW UP/DN|org/lt grn - org/wht|A |drivers window switch       |
| RF WINDOW UP/DN|org/tan - org/gry   |A |drivers kick panel          |
| LR WINDOW UP/DN|org/blu - org/lt blu|A |drivers kick panel          |
| RR WINDOW UP/DN|org/gry - org/grn   |A |drivers kick panel          |
|        RADIO 12V|gray/red            |+ |radio                      |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|blue/pink           |+ |radio                      |
| RADIO ILLUMINATE|ORANGE / tan          |+ |radio                      |
|       LF SPEAKER|green - grn/brn     |   |radio                      |
|       RF SPEAKER|gray - gray/brn     |   |radio                      |
|       LR SPEAKER|grn/blu - grn/org   |   |radio                      |
|       RR SPEAKER|gry/blu - gry/org   |   |radio                      |
Notes:
NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v. *2 The BCM is in the drivers kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. *3 Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays. *4 There are separate door triggers for each door, they are all in connector 3 at the BCM. The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four and diode isolate each. See directfax document #1076 for wiring information. *5 Arm is negative trigger thru a 1.5K ohm resistor, this will also lock the doors. Disarm is negative trigger thru a 9.1K ohm resistor, if use double pulse this will also unlock the doors. MUST use relays. *6 On the 2.4L use blue/green or blue/tan. On the 3.3L/3.8L use blue/green, blue/tan or blue/orange.   *7 The PCM is behind the driver side headlight. VSS is in the gray plug, pin 66. *8 The parking lights are negative trigger thru a 2.1K ohm resistor. The headlights are negative trigger thru a 790 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See directfax document #1082 for wiring information. *9 A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights. *10 Hatch release is PURPLE / tan in connector 2, pin 6 at the BCM. It is negative trigger thru a 1.69K ohm resistor. Left power sliding door is PURPLE / blue in connector 3, pin 1 at the BCM. It is negative trigger thru a 1.5K ohm resistor. Right power sliding door is the same wire as the left and it is negative trigger thru a 2.7K ohm resistor. Must use relays. *11 Accessory is not required for remote start. *12 The second starter wire is negative trigger thru a 180 ohm resistor. MUST use relay. Refer to directfax document #1083 for wiring information.
Be careful whose advice you buy, but be patient with those who supply it.Need wiring diagram 2001Town and Country -- posted image.
homey88
Member - Posts: 42
Posted: March 08, 2005 at 10:30 PM / IP Logged
Thanks for the info!
Brian
