2003 F250 Diesel
ultimateshrub
Member - Posts: 22
Posted: November 06, 2002 at 3:58 AM / IP Logged
I am looking for a wiring schematic for a 2003 F250 Diesel so that I can install a AstroStart Car Starter.  Any advice and info. would be greatly appreciated.
Brad
dljbrla
Member - Posts: 23
nass
Posted: November 06, 2002 at 7:34 PM / IP Logged
  •          here are the wiring colors for a 2003 ford diesel                         RED / lt.blue starter wire  dk.blue/lt.green ignition 1 RED / black ignition 2 gray / YELLOW heater BLACK/ lt.green accessory location ignition harness. tach signal maybe behind insterment cluster WHITE/ pink. I would recomend using a tach generater it works much beter.Parking ligth wire is brown at switch. Diesel WAIT TO START LIGTH IS BLACK/ PINK+ AT CLUSTER.     IF YOUR UNIT HAS TIMER FOR WAIT TO START YOU CAN USE INSTEAD OF CONECTING TO WIRE. Lock wire is pink/lt. green Unlock wire pink/lt.yellow wires can be found in drivers kick negative trigger if truck has keyless entry if not reverse polarity.
nascar
ultimateshrub
Member - Posts: 22
Posted: November 06, 2002 at 9:24 PM / IP Logged
ultimateshrub
Member - Posts: 22
Posted: November 06, 2002 at 9:30 PM / IP Logged
Hello Nass
Thank you for the very helpful info.  I have a few more questions.  Would it be ok to contact you via phone?  I am in Edmonton Alberta and will pay for the call.  Alternatively, you can reach me at 877-975-6434.
Thanks again
Brad
ultimateshrub
Member - Posts: 22
Posted: November 06, 2002 at 9:31 PM / IP Logged
Hello Dljbrla
Thank you for the advice also.  It is much appreciated.
Brad
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
