Clifford sirens, interchangeable?
MestizoRacer310
Copper - Posts: 53
Posted: March 14, 2005 at 7:31 PM / IP Logged
I've got an Intelliguard 700 that I got used off ebay w/ a bad speaker siren. If I remember correctly it's called the "Medallion."   Now my question is would a "normal" siren (horn type) work w/ my output or am I stuck trying to find the medallion "speaker" type siren. Also would the Insignia siren work, or the ones off the Matrix series?
Kevin
'02 Acura TL Type S & '98 Accord EX-L Sedan
cosmoworks
Copper - Posts: 144
Posted: March 15, 2005 at 10:59 AM / IP Logged
A normal siren won't work using the same outputs, but you can use it using the brain's yellow siren output wire. However you lose your warning stage output.
