04 avalanche tach wire
slimcox
Member - Posts: 6
Posted: March 16, 2005 at 9:29 PM / IP Logged
Can anyone help me I'm having problems fing the tach wire for 04 avalanche.
ecox
thepencil
Gold - Posts: 1,526
Posted: March 16, 2005 at 10:23 PM / IP Logged
Locate the PCM in the engine compartment. PCM is right beside the battery.
Tach wire is WHITE.
DEI Info. Note
CHEVROLET, AVALANCHE, 2004, Tachometer
The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Be careful whose advice you buy, but be patient with those who supply it.04 avalanche tach wire -- posted image.
chris354
Silver - Posts: 253
Posted: March 17, 2005 at 12:07 AM / IP Logged
I would just pull cluster it,s easy to remove. it will should be the only white wire at the plug on top of cluster.
SoundExplosion
Copper - Posts: 48
Posted: March 17, 2005 at 11:05 AM / IP Logged
EACH COIL HAS FOUR WIRES USE UNCOMMON WIRE        DO NOT USE THE BLACK, BROWN, OR PINK.  USE THE WIRE THAT IS NOT THE COLOR THAT IS MENTIONED
SoundExplosion
"You are only as good as your last install"
" T-taps should never be used"
