790xv and turbo timer?
kyden
Posted: March 17, 2005 at 12:53 AM / IP Logged
is there any way to integrate a turbo timer into the 790xv?
gus1
Gold - Posts: 1,013
Posted: March 17, 2005 at 1:40 PM / IP Logged
it already has one.....
Gus
kyden
Posted: March 18, 2005 at 11:16 AM / IP Logged
negative. 791 has it.. 790 doesnt
profuse007
Gold - Posts: 2,015
Posted: March 18, 2005 at 11:56 AM / IP Logged
you better off wire the turbo timer independently.
maybe, if you want it to arm itself atfer the turbo timer elapsed, then send a negative or postive pulse(viper has both) to the door trigger while the turbo timer is on.
while doin so, you need to program ur 790xv to passively lock and arm. also, turn off the force to arm while goin through the programming. "force to arm" is ON by default.
Houston,TX
