2000 Lexus es300
Dohoa
Member - Posts: 15
Posted: March 17, 2005 at 10:19 AM / IP Logged
I am going to install an alarm and remote start to 2000 Lexus es 300. need to locate the tach wire and disarm wire when using a remote start. any opinion and diagram for this car, I am thanking in advanced
thepencil
Gold - Posts: 1,526
Posted: March 17, 2005 at 10:22 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - LEXUS / ES 300 / 2000 / Remote Start
12volts white - WHITE/ red    +   ignition harness
Starter red    +   ignition harness
Second Starter
Ignition BLACK / YELLOW    +   ignition harness
Second Ignition BLACK/ red    +   ignition harness
Notes: There are two BLACK/ red wires going to the same pin at the plug. use either one.
Third Ignition
Accessory blue/red    +   ignition harness
Second Accessory
Keysense
Power Lock dk. blue/white    -   theft module
Notes: The theft module is at the front of the center console under the radio. The lock wires are about 18 gauge. They will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself.
Power Unlock dk. blue    -   theft module
Lock Motor blue/red      org plug bottom of fusebox
Unlock Motor blue      org plug bottom of fusebox
Parking Lights+ grn/org or grn/blk      bottom of fusebox
Notes: In a white connector just below the fuses with the wires exiting out toward you.
Parking Lights- green      steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white    -   top of fuse box
Notes: Located in a seven pin plug on the top right side of the fuse box.
Dome Supervision
Trunk/Hatch Pin RED / yellow    -   trunk light or theft module
Hood Pin black    -   pin switch or theft module
Trunk/Hatch Release red    -   release switch
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer gray
Notes: On the 6 cylinder motor use the gray wire located at the ignitor on a bracket just in front of the driver side strut tower. The module says *Denso* on it.
Wait to start
Brake Wire GREEN / WHITE    +   bottom of fusebox
Parking Brake
Horn Trigger GREEN/ black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 555X, 556U, or 555U
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.2000 Lexus es300 -- posted image.
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
