Car Starter on a 1997 Mercedes C280
RacingStripes
Posted: March 19, 2005 at 10:43 PM / IP Logged
Hi
WE have installed a car starter on a 1997 Merc. C280. Everything works fine but the starter. It is acting like the key has a chip in it but it does not. I checking in the www,12voltdirect.com site and the transponders started in 98. Would I need to hook up the key sense wire? HOw would I know the polarity of it?
Platinum - Posts: 12,488
Posted: March 20, 2005 at 1:12 AM / IP Logged
Use PURPLE / green to bypass factory starter kill for remote start. Vehicle also has a 2nd IGN wire ( test to see if voltage drops during start, if it does, set up as 2nd ACC instead ).
burner
Member - Posts: 20
Posted: March 20, 2005 at 11:55 AM / IP Logged
Hey Velocity.. Can you tell me the location of the PURPLE / green wire?
KarTuneMan
Platinum - Posts: 7,056
Posted: March 20, 2005 at 12:18 PM / IP Logged
Its in the ign. harness
burner
Member - Posts: 20
Posted: March 20, 2005 at 1:41 PM / IP Logged
Hmm.. it is not there.. Any other location you have?
burner
Member - Posts: 20
Posted: March 20, 2005 at 1:44 PM / IP Logged
Astroflex says.. its under the fuse box but the wire is not there. ... ? Someone else told me there is an immobilizer for the car wituh the switchblade key.. can any one confirm that or not
Thanks a gain
cutter1122
Copper - Posts: 103
Posted: March 20, 2005 at 10:31 PM / IP Logged
+12 Volts                          Red Ignition Harness +
Ignition                              Pink/red Ignition harness +
Accessory                         Pink/green Ignition harness +
Starter                               Purple Ignition harness +
Tachometer                       GREEN/ YELLOW At coil AC
Lock                                 Black either kickpanel -
Unlock                              Blue either kickpanel -
Doorpin                             BROWN / gray and gray/blue factory alarm -
Arm                                  Arms with lock either kickpanel -
Disarm                             Disarms with unlock wire either kickpanel -
Brakeswitch                     BLACK/ red At brake pedal switch +
Parking Lights                  Gray & Gray/white At switch +
Trunk Release                  Add Solenoid N/A N/A
