02 Mitsubishi Montero Limited Wiring
Era1
Member - Posts: 13
Posted: March 21, 2005 at 7:36 PM / IP Logged
Hello everyone.
I need a 2002 Mitsubishi Montero Limited Wiring Diagram for the remote star and the alarm. Also Need the door lock wiring too.
Thanks!!02 Mitsubishi Montero Limited Wiring -- posted image.
ken984
Copper - Posts: 78
Posted: March 21, 2005 at 8:31 PM / IP Logged
Here you go. Make sure to read the notes!!!
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=3447&product=Remote%20Start
Era1
Member - Posts: 13
Posted: March 21, 2005 at 9:22 PM / IP Logged
Thanks Ken984.
I have few more question. I'm instaiing the clifford RS3.5 into this car. the R/S has 2 12V wire and 2 ingition wire. Can I connect 2 12V wire to the singel 12V power and 2 Ignition wire in to single ignition wire.
Do I need a relay for the power lock or I can jsut direct connect it into the alarm with 1A diodes. Also the door tigger wire. Is it only 1 wire for the all 5 doors or did they have different wire for the drive and passanger doors.
ken984
Copper - Posts: 78
Posted: March 21, 2005 at 10:46 PM / IP Logged
Wire both 12v wires to the 12 v wire in the truck, the 2 ignition wires are for vehicles that have 2 powered ignition wires that need to be energized to properly start, the Montero just shows one wire so insulate the 2nd wire. The techsoft says just use the diodes for the door locks, no relay required. Yes GREEN/ red is for the entire car all doors.
