horn help
Mexbaja
Member - Posts: 29
Posted: April 29, 2002 at 7:32 PM / IP Logged
I'VE INSTALLED AN ALARM IN MY 90 HONDA ACCORD EX
BUT I'M HAVING PROBLEMS WITH THE HORN
THE ALARM HAS AN NEGATIVE OUTPUT UP TO 500MA
AND THE CAR HAS A NEGATIVE WHEN I PUSH THE SWITCH BUT REST IN POSITIVE
WHEN I ARM AND DISARM THE ALARM THE HORN DOESN'T WORK
CAN SOME BODY TELL ME WHAT TO DO   THANKS AVERYONE
sERgIO
Platinum - Posts: 12,488
Posted: April 29, 2002 at 8:09 PM / IP Logged
What kind of alarm do you have ? Sometimes the alarm does not activate the horn unless it has been triggered. If you want the horn to honk for arming and disarming verification, use the siren output wire if it's a negative output.
Mexbaja
Member - Posts: 29
Posted: April 29, 2002 at 9:12 PM / IP Logged
IT'S  IMPULSE RES-R
REMOTE START WITH KEYLESS ENTRY AND THIS MODEL DOESN'T HAVE A SIREN OUTPUT ONLY FOR THE HORN
sERgIO
Posted: April 29, 2002 at 9:20 PM / IP Logged
You may need a relay to boost the negative trigger of the RES-R to give it a more solid negaitive signal. Wire a relay in this way:
  • 30 - Output to HORN wire on car
  • 85 - BROWN wire from alarm
  • 87 - GROUND to chassis of car
  • 86 - 12 volts constant
  • 87a - NOT USED
Please post your results to see if this will help. Otherwise you may have a faulty HORN wire. Check to see if the BROWN wire does indeed output a negative signal .
Mexbaja
Member - Posts: 29
Posted: April 29, 2002 at 9:26 PM / IP Logged
THANK YOU VERY MUCH JEFF
I'LL TRY TOMORROW AND I LET YOU KNOW
THANK'S
sERgIO
Thinkster
Copper - Posts: 94
Posted: April 30, 2002 at 3:48 AM / IP Logged
Quote: Originally posted by MEXBAJA on April 29, 2002
IT'S  IMPULSE RES-R
An IMPULSE Huh?  I had experince once with that crappy brand!  Last time I used that brand.   The circuitry inside was poor design and they couldn't even give you a STANDARD siren output !  I ended up having to do some circuit modifications to do what I needed it to do.  From what I remember, the Horn output was a pulsed negative and was tied in with the same output that controls the parking light flash relay.   So in this case, you might as well use the parking light output to control the horn.   However,  you won't get your arm/disarm chirps with either of the outputs.
My suggestion:   use a reputable brand.   otherwise Good luck!
Mexbaja
Member - Posts: 29
Posted: April 30, 2002 at 9:29 PM / IP Logged
I just did what Jeff toll me, It works"     thank's Jeff
hey Thinkster I know this kind of alarm is  not the best
but where can I find reputable brand in moderate price????????I live in L.A. area
thank's for u help
sERgIO
Mexbaja
Member - Posts: 29
Posted: April 30, 2002 at 9:40 PM / IP Logged
Thank's
sERgIO
Thinkster
Copper - Posts: 94
Posted: May 01, 2002 at 12:52 AM / IP Logged
Well, I'm not sure what you consider a moderate price, but I typically stick with a brand called Megalarm in the 45-65 range.   I know the Impulse you can get for like $25-$40 range,  but you end up getting what you paid for.   In the LA area huh?  I'm not sure if there's and good brands in downtown,  The ones I use I get from the manufacturer/distributor.
Posted: May 01, 2002 at 5:08 AM / IP Logged
Good to hear that things worked out. If the Impulse system you have is working properly now, there's no need to buy another alarm . If you feel that you need to upgrade this system in the near future you will have more than enough choices out there for entry level alarm systems and remote starters.
