2003 oldsmobile alero, alarm/remote start
absolute_honda
Member - Posts: 12
Posted: April 03, 2005 at 4:09 PM / IP Logged
I need alarm/remote start wire color list for a 2003 oldsmobile alero - any help would be greatly appreciated
boomer_106
Silver - Posts: 710
Posted: April 03, 2005 at 11:08 PM / IP Logged
Oldsmobile
Alero
2003-2004
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
Yellow (+)*
Ignition switch harness*
Ignition  #1:
Pink (+)
Ignition #2:
Dk.Green (+)
Ignition  #3:
N/A
Accessory:
Orange (+)
Brake  Light:
Lt.Blue (+)
Brake pedal switch
Tach  Signal:
White or PURPLE / White (AC)
At the PCM**
Parking Lights:
Brown (+)
Gray plug at the BCM***
Headlights:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *This vehicle is equipped with GM's Passlock II Anti-Theft Security System. Use Universal Alarm Bypass Module part #2x402 where X can be any number.**On the 2.2L models use white wire in the black plug. On the 3.4L models use PURPLE / white in the blue plug. The Powertrain Control Module (PCM) is under the driver side dash left of the steering column. ***The Body Control Module (BCM) is between the blower motor and the passenger side kick panel.
Oldsmobile
Alero
2003-2004
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Red & RED / Black (+)
OEM Alarm Disarm:
N/A
Dome  Lights/Superv:
White (-)
Pink plug at BCM***
OEM Horn:
Black (-)
Gray plug at BCM***
Power  Lock:
White (-)
Gray plug at BCM***
Power  Unlock:
Same wire as power lock
Gray plug at BCM***
Trunk  Release:
Black (-)
Gray plug at BCM***
Alarm  Input Wire:
White (-)
Pink plug at BCM***
Notes:
