Viper 791XV satellite relay?
Pjx
Member - Posts: 14
Posted: April 03, 2005 at 9:06 PM / IP Logged
Do i need to install the satellite relay? I'm installing the system on a 94 Honda Civic 5 speed and i'm not going to use the remote start. Would i need to install this relay to program the brain using the valet switch? Any help would be appreciated...Thanks
profuse007
Gold - Posts: 2,015
Posted: April 03, 2005 at 9:35 PM / IP Logged
youll need that 7-pin harness for that goes to the satellite relay. the yellow wire will need to be hook up to the ignition for programing and some other functions to work.
instead of usign that 7pin harness, modify the 4pin harness thats at the satellite and plug it up to the 7pin connector. and mark the ignition input (yellow wire) accordingly.
Houston,TX
Pjx
Member - Posts: 14
Posted: April 03, 2005 at 11:42 PM / IP Logged
Could you draw a simple sketch?
clank
Member - Posts: 35
Posted: April 06, 2005 at 12:04 AM / IP Logged
You might as well hook it up. You do not need to hook up the two red wires. If you are doing an alarm it has built in starter kill. green goes to key side and purple to starter side.
shocker
dare_ds69
Silver - Posts: 419
Posted: April 06, 2005 at 5:57 AM / IP Logged
you can hook up everything and just don't ground the (18ga) BLACK/ white 5 pin plug that way the remote start don't work at all
how own your mind, control your life.
MECP certified. always use a DMM
xtremeaudio
Copper - Posts: 174
Posted: April 07, 2005 at 4:59 AM / IP Logged
YOU ONLY NEED INSTALL THE PINK WIRE FOR ING  THAT ALL YOU NEED TO DO
dare_ds69
Silver - Posts: 419
Posted: April 07, 2005 at 5:54 PM / IP Logged
XTREMEAUDIO what  about the STARET KILL ?
