2002 Grand Am door locks
d.medic
Member - Posts: 18
Posted: April 11, 2005 at 7:05 PM / IP Logged
So I read all the post on the one wire lock system and I'm still having a problem. I'm installing an Ungo RK1 with on board relays. The vehicle will unlock fine but still will not lock. I only used a relay in the lock wire with the resistor. I see some post say to use a relay on both. Is this my problem??
Thank
Platinum - Posts: 12,488
Posted: April 11, 2005 at 8:10 PM / IP Logged
Must close doors to lock with a single pulse.
d.medic
Member - Posts: 18
Posted: April 11, 2005 at 8:19 PM / IP Logged
yes but do I need a relay on lock and unlock??
thank you
eurotek
Copper - Posts: 58
Posted: April 11, 2005 at 9:35 PM / IP Logged
yes u do
Posted: April 11, 2005 at 10:06 PM / IP Logged
Depending on the system that is being used you may get away without using a relay. Try closing the door and seeing if it locks for you. If it doesn't then you need a relay.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
