04 chevy suburban alam?
nava94
Silver - Posts: 296
Posted: April 14, 2005 at 10:53 PM / IP Logged
anyone have the shematic for  2004 suburban. thankz.
mo12v
Posted: April 14, 2005 at 10:59 PM / IP Logged
POOF...............
Constant 12 voltsRED OR RED / WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightLF DOOR GREY/BLACK (-)RF BLACK/ WHITE REAR DOORS LT GREEN &*
Trunk Pin SwitchPINK/BLACK (-)AT BCM **
Parking LampGREY/BLACK (-)HEADLIGHT SWITCH ***
Power LockGREYIN EACH DOOR ****
Power UnlockTANDUE TO MULTIPLEXING
* LT BLUE/BLACK, Front Doors Located In Each Door, Rears Are At BCM ** BCM Located Under Rear Seat *** Parking Light Wire Has Also Been Seen As BROWN / WHITE (+) High In Dr Kick **** Door Lock Module Available Call OMEGA For Details
Reversal Rest At Nothing Door Lock Circuit
Accessories
Window UpD\ BLUE P\ BLUE D\ BLUE P\BLUE @ Each Switch Due To Data Link
Window DownF/ BROWN F/ BROWN R/ BROWN R/BROWN
Ign Key WarnLIGHT GREEN (-)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsWHITE (-)AT HEAD LIGHT SWITCH
OEM Alarm ArmFACTORY TRANSMITTER
OEM Alarm DisarmLT GREEN (-)AT DOOR MODULE INSIDE DRIVERS DOOR
Reversal Rest At Ground Type Window Circuit Wiring
Remote Start
Tach SignalWHITEAT PCM *
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyWHITE (-)PCM CONN C3 PIN #13 *
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightLIGHT GREEN (+)EITHER TAIL LT ASSY OR TRAILER CONN
Rear Window DefrostN/A
*PCM Located On The Drivers Side Of The Motor. Tach Wire Is In The BLUE Conn (C1) Closest To The Firewall,Pin #49. Also Found Back Of Cluster in 24 pin GREY Conn Pin # A12 NOTE: Use GREY/BLACK @ FUSE BLOCK To Activate Remote Start From OE Keyless
G.M. Passlock II Bypass  (Use The YELLOW (For Signal) And BLACK (For Reference) Wires)
MO
