truck shuts off when doors unlock
goldenchild7801
Member - Posts: 12
Posted: April 15, 2005 at 9:50 AM / IP Logged
I installed a mannix 700sm not to long ago, i dont know if its something i did or just settings on the remote. The remote autostart/alarm is on a linclon navigator 2000. I can start the truck with the remote auto start, the doors lock automatically, when i go to get into the truck, i press unlock and the truck shuts down, i only have the hood pin connect, no shock or radar sensing
mo12v
Posted: April 15, 2005 at 12:57 PM / IP Logged
Isn't that part of Mannix system??  U might check instructions.........
MO
floaterr
Silver - Posts: 383
Posted: April 15, 2005 at 4:26 PM / IP Logged
Did it do it from the start? Did it just suddenly start happening?
floaterr
Silver - Posts: 383
Posted: April 15, 2005 at 4:30 PM / IP Logged
One more thing. You didn't happen to install the hood pin wire to the alarm negative hood pin wire without a diode? I see that the Autopages have seperate remote start and alarm hood pin inputs and they are not suppose to be tied together without a diode.
Anyway just throwing thoughts out there for ya.
goldenchild7801
Member - Posts: 12
Posted: April 18, 2005 at 11:27 PM / IP Logged
got bored and played around with the remote start found out the problem was operator error, i guess i was just in a rush when ever i went to unlock the doors and i held the unlock button alittle too long which shuts off the truck, problem solved
Monday, January 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
