2005 Monte Carlo
MKJfb32
Posted: April 27, 2005 at 5:51 AM / IP Logged
Okay here's the gig,  I put a security system with keyless and got everything working, but here's the kicker.  Whenever driving down the road and you switch from bright to low headlights, the headlights start blinking and when you park after this endeavor, open the door the aftermarket security or the siren goes off.  I'm looking for some tips or advice if anyone knows or has some.  I think.. that the factory security is arming, making the headlights blink and triggering the aftermarket.  But, I'm not 100% sure, so if anyone has any ideas let me know.   Thanks
mkj
mo12v
Posted: April 28, 2005 at 8:29 PM / IP Logged
I'd be looking at the Install..............Check the Input to the lights.  Sounds like the Alarm is turning on from the Light switch.............Did U tap into the Parking Lites or the Headlites??
MO
nava94
Silver - Posts: 296
Posted: April 28, 2005 at 10:51 PM / IP Logged
check your wiring. you might have connected to the wrong 12volts or ignition.check your ground also.
