Toad C4
dbennett9
Posted: May 01, 2005 at 3:22 PM / IP Logged
Hi, i dont know if  anyone has experience of these alarms, i know that they arn't common in USA.
I have realised that the Toad C4 installed on my Honda Prelude 1990, is really badly done, no hood switch, no door pin tie in, wires loose in the engine bay. All the connections are easily seen, and loads of wires lead no where, no solder ANYWHERE.
Also for some reason there are two window closure modules when it works with one.
I really need the wiring diagram for this alarm, or a contact for someone who can get them for me.
Thanks in advance
Dan Bennett
joe_1
Silver - Posts: 286
Posted: May 06, 2005 at 5:47 AM / IP Logged
hi you are right i dont think these are known over in the usa i have only fitted the a1606 cat 1 toads so i dont think that the c4 should be a problem if you look on ebay you can get a disc that has all the toad diagrams on it for about £5.00 if that helps good luck.
