2002 Acura 3.2 TL type-s
derek c
Posted: November 15, 2002 at 8:41 PM / IP Logged
Does anyone if you can run the factory alarm system and a compustar remote start security system together with the aftermarket remote. Where is the factory alarm module and does anyone have wiring diagrams of it, any help or info will be much appreciated thanks
dc
Platinum - Posts: 12,488
Posted: November 15, 2002 at 10:52 PM / IP Logged
Yes, the Compustar can integrate witht e OEM factory alarm system. I think the alarm module is located behind the glove box. Here is the wiring diagram:
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|BLACK/ blue          |-  |passenger fuse box *1       |
|     POWER UNLOCK|orange              |-  |passenger fuse box *1       |
|       LOCK MOTOR|WHITE/ red           |   |drivers fuse box *2         |
|     UNLOCK MOTOR|yellow              |   |drivers fuse box *2         |
|    DISARM DEFEAT|lt. GREEN/ red       |   |passenger MUX module *3     |
| PARKING LIGHTS +|RED / black           |   |passenger kick panel        |
| PARKING LIGHTS -|RED / yellow          |   |left of steering column     |
|       HEADLIGHTS|blue/red            |-  |left of steering column     |
|     DOOR TRIGGER|BLACK/ white         |-  |passenger fuse box          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|blue/green          |-  |drivers fuse box            |
|         HOOD PIN|yellow              |-  |passenger fuse box          |
|TRNK/HTCH RELEASE|WHITE/ red           |+  |passenger MUX module *3     |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|blue                |-  |drivers door key cylinder   |
|       TACHOMETER|blue                |   |drivers shock tower *4      |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|WHITE/ black         |+  |brake switch                |
|     HORN TRIGGER|lt. GREEN/ blue      |-  |steering column             |
|           WIPERS|blue & blue / YELLOW  |-  |left of steering column     |
|  LF WINDOW UP/DN|RED / yel - RED / blu   |A  |drivers window motor        |
|  RF WINDOW UP/DN|blu/wht - blu/yel   |A  |RF window switch            |
|  LR WINDOW UP/DN|RED / blu - RED / yel   |A  |LR window switch            |
|  RR WINDOW UP/DN|RED / blk - RED / yel   |A  |RR window switch            |
| SUN RF OPN/CLOSE|grn/yel - grn/red   |A  |relays left of fuse box     |
|        RADIO 12V|WHITE/ green         |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|WHITE/ red           |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                       |
|       LR SPEAKER|blu/yel - gry/wht   |   |radio                       |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio                       |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555H or 555U.  *1 Located in a green 20-pin connector. Use the key switch in the passenger door to test.  *2 Located in a green 18-pin connector.  *3 The passengers MUX module is located behind the glove box.    *4 In a 2-pin connector near the air intake on the drivers side shock tower.
derek c
Posted: November 16, 2002 at 7:30 PM / IP Logged
Hey Jeff thanks for the quick respond,  you wouldn't happen to know which wires to disarm and arm the factory alarm system?  I want to have both system running the same  time via the compustar remote.
dc
Posted: November 16, 2002 at 7:56 PM / IP Logged
The system arms and disarms with lock and unlock.
derek c
Posted: November 16, 2002 at 8:22 PM / IP Logged
So Jeff would you say I will just need to attach my compustar lock and unlock negative pluse wire to the WHITE/ red and yellow on the drivers fuse box to control the factory alarm.  I have already attach the power door lock wires on the passenger fuse box it is working fine for locking and unlocking all the doors.
Thanks Jeff]
derek
dc
Chris Luongo
Platinum - Posts: 3,746
Posted: November 17, 2002 at 3:50 PM / IP Logged
You'll also have to set up your unit to unlock the doors before remote starting, and then re-lock them after starting, otherwise the factory alarm will go off.  Or you can run a wire into the driver's door, as stated in the tech sheet.
derek c
Posted: November 17, 2002 at 4:59 PM / IP Logged
Chirs thanks for the advice, I will try to run a wire to the driver's door and disarm the factory alarm without unlocking  as stated (blue).  I will use the same signal wire that will activite the transponder bypass at the same time disarm the factory alarm.
Thanks Chris
derek
dc
