need alpine 8030B diagram
sawman2000
Posted: November 17, 2002 at 11:29 AM / IP Logged
Help, searched in vain all post, and web! Could someone just tell me the pin outs, or wiring diagram for a Alpine 8030B?
Thanks in advance
patmar
Copper - Posts: 69
Posted: November 17, 2002 at 2:47 PM / IP Logged
main bus 12p
yel= batt+
red= ignition+
org= starter cut -(use relay)
blue= siren +
RED / withe= disarm/valet switch+
with=light flash- (use relay)
yel/red= led flash+
with/brown=door lock -(use relay)
black=ground-
with/green= door unlock- (use relay)
sub bus 6p
BROWN / withe=doors sensor
BROWN / black=optional sensor
GREEN/ withe=hood/trunk sensor
yel/green=ext output- (use relay)
pat
Grslc
Posted: November 18, 2002 at 12:01 PM / IP Logged
yellow-constant power    red-hot in start    black-ground    blue-siren output     yellow/red stripe-interior armed light output     not sure about orange, ORANGE / white stripe, white, WHITE/ green stripe, or WHITE/ brown stripe.  Probably parking lights and door lock/unlock.  If anyone knows, your help would be appreciated.
Corrado SLC
Platinum - Posts: 12,488
Posted: November 18, 2002 at 12:06 PM / IP Logged
The wiring will be much the same as the 8040 found here: https://www.the12volt.com/downloads/file.asp?ID=277
Friday, January 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
