Keyless Entry on 94 Ford Conversion Van
esko6000
Posted: May 15, 2005 at 9:46 PM / IP Logged
Can someone please tell me how do I program the keyless entry remote on a 94 Ford Econoline Conversion Van?
mo12v
Posted: May 16, 2005 at 8:14 AM / IP Logged
For FACTORY Transmitters:
1. ) Locate 2-way programming connector @ Pass.side B Pillar.  It is a plug with a pair of WHITE / Yellow & GRAY / Yellow wires taped to harness
2.) Turn Ignition Switch to Run position.
3.) Short program connector wires WHITE / Yellow & GRAY / Yellow together.  Doors should Lock & UNLock to confirm.
4.) Remove short from connector.
5.)Press any button on Transmitter.  The doors should Lock & UNLock to confirm.  Program any other Transmitters at this time.
6.) Turn Ignition OFF.
MO
esko6000
Posted: May 16, 2005 at 11:37 PM / IP Logged
Thanks alot Mo, it worked like a charm.  I really appreciate the timely response and I hope I can be of help to anyone in the group in the future!!
