G35 remote start
rac0000
Posted: May 20, 2005 at 5:19 PM / IP Logged
I have a 2005 infiniti g35x on order and want to install a remote start.You guys helped me out big time on a remote start for my 2003 accord. I need to know what i'll need to do the job right. (modules and bypass kits?). Also a wiring diagram and wire location would be very helpful.Also,if anyone knows of any snags i may run into in the installation.
rac0000
Pearl96Max
Member - Posts: 16
Posted: May 20, 2005 at 10:51 PM / IP Logged
Congrats on your purchase. I just picked one up lastweek as as well.
All youll need is a 556U Immobilizer Bypass.
Heres the tech sheet:
DIRECTWIRE™ WIRING INFORMATION - INFINITI / G35 SEDAN / 2005 / Remote Start
[PRINT THIS PAGE]
12volts WHITE/ blue (40A)   +   ignition harness
Starter WHITE/ red   +   ignition harness
Second Starter WHITE/ green   +   ignition harness
Ignition BLACK/ red   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory WHITE/ black   +   ignition harness
Second Accessory N/A
Keysense BLACK/ pink   +   ignition harness or BCM, pin 37
Notes: The BCM (Body Control Module) is in the driver kick panel.
Power Lock RED / white   -   driver door module in door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock blue/white (double pulse)   -   driver door module in door
Lock Motor purple   5wi BCM, pin 50
Unlock Motor yellow   5wi BCM, pin 44
Parking Lights+ RED / blue   +   driver kick, harness to rear
Parking Lights- N/A
Hazards GREEN/ red   -   switch or BCM, pin 29
Turn Signal(L) GREEN / WHITE   +   BCM, pin 45
Turn Signal(R) PURPLE / white   +   BCM, pin 46
Reverse Light red or orange   +   driver kick, harness to rear
Door Trigger white (D), pink (P)(x3)   -   BCM, pins 62, 12, 63 and 13
Notes: Use all four wires and diode isolate each.
Dome Supervision PURPLE / red   -   BCM, pin 48
The step lamps are yellow/purple (-) at the BCM, pin 47.
Trunk/Hatch Pin RED / white   -   BCM, pin 57
Hood Pin lt. GREEN/ black   -   hood pin switch under hood
Trunk/Hatch Release pink or blue   -   BCM, pin 30
The trunk release motor wire is GREEN / WHITE (+) at the BCM, pin 68.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT WHITE/ blue, red or black   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire pink/blue   +   brake pedal switch
Parking Brake RED / white or PURPLE / red   -   parking brake switch
Horn Trigger GREEN/ black   -   horn switch
Memory Seat 1 blue/green   -   memory seat switch on seat
Memory Seat 2 blue/black   -   memory seat switch on seat
Memory Seat 3 N/A   -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes: Standard on all models.
Pearl96Max
Member - Posts: 16
Posted: May 20, 2005 at 10:52 PM / IP Logged
From what Ive seen so far not all the wires are 100% accurate for the '05 models. Please test and confirm all colors prior to using.
Good luck
