97 subaru legacy stock security problems
pooflinger
Posted: June 12, 2005 at 2:47 PM / IP Logged
Hello,
I'm having a hard time with my security system in my 1997 subaru legacy.  I just installed a new stereo the other day, which i have done before on this car.  (By the way the wiring diagrams on this site for subarus are pretty much all wrong so i posted the actual wire colors on the other form).
Anyway, when i hooked the battery power back up the parking lights and brakes lights flashed as part of the normal alarm procedure.  This has happened to me before but usually i could turn it off by unlocking the doors or starting up the car.
This time however, it did not.  I tried everything i could, used the remote to turn the alarm off, unlock the doors, the trunk, start it up.  Nothing.  Eventually i had to take the fuse out for the security system.   It flashes in a awkward pattern too, it will flash about every second for about 10 seconds then quit for about 5 seconds, then repeat.
I've checked the connections to the security system to see if I messed them up somehow, but they were all in place.
Does anyone else know whats going on?
dare_ds69
Silver - Posts: 419
Posted: June 13, 2005 at 6:23 AM / IP Logged
it is factory or aftermarket alarm?   if it is factory you have to close all the doors, windows, trunk everything and whait 5 minutes the using the key in the drivers door unlock tree times97 subaru legacy stock security problems -- posted image. that should fix the problem
how own your mind, control your life.
MECP certified. always use a DMM
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
