wire info 97 land rover discovery
ksutton
Copper - Posts: 94
Posted: June 14, 2005 at 9:26 AM / IP Logged
Im looking for any dei wire info on a 97 discovery land rover
thepencil
Gold - Posts: 1,526
Posted: June 14, 2005 at 11:16 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - LAND ROVER / DISCOVERY / 1997 / Remote Start
12volts brown    +   ignition harness
Starter WHITE/ red    +   ignition harness
Second Starter
Ignition yellow    +   ignition harness
Second Ignition white    +   ignition harness
Third Ignition
Accessory lt. GREEN / WHITE    +   ignition harness
Second Accessory
Keysense
Power Lock yellow/pink    F   driver kick panel
Power Unlock same wire
Lock Motor
Unlock Motor
Parking Lights+ red      4 wire plug at column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger pur/grn & pur/wht    -   security module
Notes: PURPLE / green is for the drivers door and PURPLE / white is for the 3 passenger doors. Use both and diode isolate each.
The factory security module located under the passenger side of the dash to the far right behind a panel. Held into place with two 7 mm bolts.
Dome Supervision
Trunk/Hatch Pin pur/wht or wht/pur    -   security module
Notes: The factory security module located under the passenger side of the dash to the far right behind a panel. Held into place with two 7 mm bolts.
Hood Pin PURPLE / orange    -   security module
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm blu/grn or blu    -   security module
Same wire. Pulse with lock to arm, and pulse with unlock to disarm.
Factory Alarm Disarm blu/grn or blu    -   security module
Disarm No Unlock
Tachometer     AC   ignition coil pack
Notes: The ignition coil pack is in the left rear of the engine compartment, use one of the wires that is NOT red or WHITE/ green for tach.
Wait to start
Brake Wire GREEN/ purple    -   brake switch
Parking Brake
Horn Trigger PURPLE / orange    -   security module
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.wire info 97 land rover discovery -- posted image.
