507M 507T DEI Tilt Tow Sensor
Thayer
Member - Posts: 8
Posted: June 21, 2005 at 6:52 AM / IP Logged
Does any know if the 507M, which is suppose to be the new version of the 507T, has a fix for the falsing problem that almost everybody seems to encounter, like here:
https://www.the12volt.com/installbay/forum_posts.asp?tid=41541&KW=tilt
I looked at the instructions for the 507M and everything seems the same, except they replaced the delay and sensitivity dip switches with hard wires that you cut to select modes.  If they fixed the falsing problem, I want to give this sensor a try, but I don't want to buy it and have it be a repackaged 507T.
OhioMike1101
Silver - Posts: 343
Posted: June 21, 2005 at 10:01 PM / IP Logged
I have not had a problem installing 507T units at all.
Had one in a 1997 Bravada falsing, but I had accidently set the motion to max with a 1 degree incline.  I set it to low with a 3 degree and it didn't false anymore.
nava94
Silver - Posts: 296
Posted: June 21, 2005 at 11:30 PM / IP Logged
yep same here I left the motion to low and so far no more falsing.
Thayer
Member - Posts: 8
Posted: June 22, 2005 at 6:30 AM / IP Logged
Where do you guys have it mounted?  Is it on the bare metal of the body?  Is it at a slight angle or relatively flat?
