1992 Buick Park Avenue door trigger location?
checkedout
Posted: June 27, 2005 at 9:57 AM / IP Logged
I'm having trouble locating the door trigger on a 1992 buick park avenue so I can hook up the interior lights to a remote starter. Any discription of what it looks like or where under the dash I might find it would help greatly.
Thanks!
mo12v
Posted: June 27, 2005 at 10:22 AM / IP Logged
Any Dome Light should have a WHITE wire............
Door Trigger white   -  under dash light
MO
checkedout
Posted: June 27, 2005 at 10:31 AM / IP Logged
Thanks for your quick responce. I had this information but still could not find a white in the area under the dash light that reacted when the interior lights come on.
mo12v
Posted: June 27, 2005 at 11:56 AM / IP Logged
The WHITE wire will show a NEGATIVE when the Door is open.
It is located at any Dome Light or Door Pin
MO
checkedout
Posted: June 27, 2005 at 12:24 PM / IP Logged
No white wires there. If I remember right there was a purple and a black but no white.
checkedout
Posted: June 28, 2005 at 11:12 AM / IP Logged
the underdash light has a orange wire and a blue with white stripe wire. Can I use the blue with white stripe wire?
infoaudio01
Member - Posts: 24
Posted: June 28, 2005 at 11:52 PM / IP Logged
Use a Digital Multimeter (DMM) and test both wires for a negative trigger with any door is open, positive when shut.  Test all doors.
