2000 Ram Tach
dp-labs.com
Member - Posts: 18
Posted: July 11, 2005 at 1:24 AM / IP Logged
Ok so, I am having a memory lapse,
Tach      BLACK/ Gray     At Coil
I tap this at the coil, the wire coming out of the coil..
There only 2 coming out... not including the spark plug wire.
For some reason, it is giving me like 12v and decreases when the RPMs go up....
Wrong wire?
Better place to go for this..... AND A PIC WOUDL HELP !!!
Never had an issue with tach sensor before.
Thanks !!
Platinum - Posts: 12,488
Posted: July 11, 2005 at 9:10 AM / IP Logged
The other wire nex tto the tach wire is a WHITE/ GREEN. Is this the location that you have ? The plug with the BLACK/ GRAY is located underneath the coil in a black 2 pin plug
dp-labs.com
Member - Posts: 18
Posted: July 11, 2005 at 8:23 PM / IP Logged
nah its a GREEN/ red
dp-labs.com
Member - Posts: 18
Posted: July 11, 2005 at 9:36 PM / IP Logged
Ok, the same wire that is at the ECM, does the same damn thing....
12v AC , and the voltage goes down when the RPMs are increased.
Posted: July 12, 2005 at 12:13 AM / IP Logged
Check you email. I sent you a image of where to look for the tach
