wiring diagram for 1999 maxima
oasis475
Member - Posts: 25
Posted: July 11, 2005 at 8:54 PM / IP Logged
hey, can on post the correct wiring diagram for 1999 maxima SE limited. i found few website but some of the color dont much. If somebuddy can post a reliable diagram(Preferably from DIRECTWIRE), i will be thankful you guys
swamprat323
Gold - Posts: 1,335
Posted: July 11, 2005 at 9:22 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|wht/red - wht/pur *6|+ |ignition harness            |
|          STARTER|blk/yel - blk/wht *6|+ |ignition harness            |
|   SECOND STARTER|grn/blk - RED / blu *6|+ |ignition harness            |
|        IGNITION|blk/wht - blk/red *6|+ |ignition harness            |
|        ACCESSORY|RED / yel - red *6    |+ |ignition harness            |
| SECOND ACCESSORY|blue - wht/blu *6   |+ |ignition harness            |
|       POWER LOCK|lt. GREEN/ red       |- |in drivers door at switch   |
|     POWER UNLOCK|GREEN/ YELLOW *1     |- |in drivers door at switch   |
|       LOCK MOTOR|BROWN / white        |   |in drivers door at switch   |
|     UNLOCK MOTOR|brown               |   |in drivers door at switch   |
|    DISARM DEFEAT|brown               |   |in passenger door at switch |
| PARKING LIGHTS +|RED / green           |   |steering column             |
|       HEADLIGHTS|gry/yel(L)blu/blk(R)|+ |steering column             |
|     DOOR TRIGGER|RED / white           |- |low in drivers kick        |
| TRUNK/HATCH PIN|purple / YELLOW       |- |drivers kick or BCM *2      |
|        HOOD PIN|yellow/black        |- |BCM *2                      |
|TRNK/HTCH RELEASE|purple / YELLOW       |- |low drivers kick *3        |
| FCTRY ALARM ARM|arms w/ lock        |   |                            |
|FCTRY ALRM DISARM|disarms w/ unlock   |   |                            |
| DISARM NO UNLOCK|*4                  |   |                            |
|       TACHOMETER|WHITE/ green        |   |ECM *5                      |
|      SPEED SENSE|pink/blue           |   |instrument cluster          |
|       BRAKE WIRE|RED / green           |+ |at brake switch             |
|     HORN TRIGGER|GREEN / WHITE        |- |                            |
|           WIPERS|lt. GREEN/ red       |- |steering column             |
| LF WINDOW UP/DN|blu/red - blu/blk   |A |in LF door at switch        |
| RF WINDOW UP/DN|blu/red - blu/blk   |A |in RF door at switch        |
| LR WINDOW UP/DN|blu/red - blu/blk   |A |in LR door at switch        |
| RR WINDOW UP/DN|blu/red - blu/blk   |A |in RR door at switch        |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555U to bypass. *1 Requires a double pulse. *2 The BCM (body control module) is located just below the radio. *3 Must use a relay to interface with this circuit. *4 A single negative pulse to the unlock wire will disarm without unlocking. *5 The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left. DO NOT UNPLUG THE ECM. *6 The ignition harness wires change color at a plug. The above listed colors show both sides of the plug.
i have found all wire guides to be worng form tiem to tiem. just use a meter to fidn the ones you need.
Sunday, May 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
