2002 Mitsubishi Diamante, USA
Anatoly
Member - Posts: 6
Posted: July 20, 2005 at 2:07 PM / IP Logged
Please prompt where to find colours of wires of Mitsubishi Diamante 2002 (u.s.a.)
swamprat323
Gold - Posts: 1,335
Posted: July 20, 2005 at 5:45 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |steering column             |
|          STARTER|BLACK/ red           |+ |steering column             |
|        IGNITION|BLACK/ white        |+ |steering column             |
| SECOND IGNITION|blue/red            |   |                            |
|        ACCESSORY|blue/white          |+ |steering column             |
|       POWER LOCK|blue               |- |in drivers door             |
|     POWER UNLOCK|RED / green *1        |- |in drivers door             |
|       LOCK MOTOR|blue/red            |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/black          |   |drivers kick panel          |
|    DISARM DEFEAT|blue/black          |   |passengers kick panel       |
| PARKING LIGHTS +|GREEN / WHITE        |   |dimmer switch               |
| PARKING LIGHTS -|GREEN / WHITE        |   |headlight switch            |
|       HEADLIGHTS|RED / yellow          |- |headlight switch            |
|     DOOR TRIGGER|GREEN/ orange        |- |underdash light             |
| TRUNK/HATCH PIN|green or grn/blk    |- |drivers kick panel          |
|TRNK/HTCH RELEASE|RED / yellow          |- |at switch                   |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|BROWN / green        |- |drivers kick panel *2       |
|       TACHOMETER|wht/grn or white    |   |at coil pack               |
|      SPEED SENSE|WHITE/ blue          |   |diag connector near column |
|       BRAKE WIRE|green               |+ |at brake pedal              |
|     HORN TRIGGER|grn/red or RED / wht |- |steering column             |
|           WIPERS|blu/org, blu/red    |+ |wiper motor                 |
| LF WINDOW UP/DN|blu/red - grn/blk   |A |in LF door at switch        |
| RF WINDOW UP/DN|blu/red - grn/blk   |A |in RF door at switch        |
| LR WINDOW UP/DN|RED / blk - grn/blk   |A |in LR door at switch        |
| RR WINDOW UP/DN|RED / blk - grn/blk   |A |in RR door at switch        |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555U to bypass. *1 A single pulse unlocks just the drivers door, and a double pulse will unlock all of the doors.    *2 This is the trunk key cylinder wire, it is in the harness running to the rear of the vehicle. Metering by turning the key in the trunk.
Anatoly
Member - Posts: 6
Posted: July 24, 2005 at 3:19 AM / IP Logged
swamprat323
Thank for the answer.
