Avital AMX 8 Q Start doesn't work anymore
ashish28
Posted: July 21, 2005 at 9:50 PM / IP Logged
I have a Honda Accord 1996 EX and my remote start doesn't work anymore (Avital AMX 8 Q Start)
What could be the problem and how can it be resolved?
Thanks,
Ashish
swamprat323
Gold - Posts: 1,335
Posted: July 22, 2005 at 12:04 PM / IP Logged
Does everythign eles work on the alarm?
Does the alarm have shut down diagnistic?
Does it igntion come on then dies?
waht all happens whne you try yo RS?
ashish28
Posted: July 22, 2005 at 2:02 PM / IP Logged
I have the security system that works, I can also open the doors with the RS keys. Only thing that doesn't work is the self start.
swamprat323
Gold - Posts: 1,335
Posted: July 22, 2005 at 5:34 PM / IP Logged
does it try to start or nothing happens. does the igntion come on. give us all the info that you can. was it set for tach or tach less. also does that alarm have a shut down diagnostic.
Platinum - Posts: 12,488
Posted: July 22, 2005 at 6:21 PM / IP Logged
Check to see if you hood pin switch is grounded.
ashish28
Posted: July 22, 2005 at 9:46 PM / IP Logged
Nothing happens when the button is pressed. No the ignition doesn't come on.
What is tach? How do I know if the alarm has a shutdown diagnostics?
I will check the hood switch grounding? Is there a specific location to look for?
Also note that my hood doesn't close properly sometimes.
Thanks for your inputs.
