00 Honda civic Neutral safety Wire
Johnnynguyen20
Copper - Posts: 89
Posted: July 22, 2005 at 9:22 PM / IP Logged
Is there any one know where is the Neutral Safety Wire from a 00 Honda civic ?
Thank you
Johnnynguyen
auex
Platinum - Posts: 5,041
Posted: July 23, 2005 at 12:21 AM / IP Logged
Doesn't have one. If car is auto then ground it. If car is manual then you shouldn't put a remote start in.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
iskidoo
Silver - Posts: 1,047
Posted: July 23, 2005 at 11:04 AM / IP Logged
If it is manual you can purchase a remote start unit that it specifally designed for use in a manual transmission vehicle. Do a search on this forum and read up on it. The units will require connecting a few additional circuits and setting the vehicle up into a reservation mode to ensure safe remote starting each time. DEI also makes a unit that will adapt Auto units for manual use. Please do use the right equipment and be safe. Have you already purchased a unit? What brand/model?
