83 deville remote start
mrjc480
Member - Posts: 44
Posted: July 26, 2005 at 11:01 AM / IP Logged
im doing a remote start on a 83 cadillac deville and during activation the starter will crank but it will not stay started.  i have 12+ constant  and 12+ ignition when remote start is engaged.  when i jump the 12+ constant to the ignition the engine will stay running.  is there a possibility that the relay is not is not putting out enough amperage?  please help me out, thank you
Im moving to MEXICO and Im not speaking spanish!
mrjc480
Member - Posts: 44
Posted: July 26, 2005 at 12:26 PM / IP Logged
yes i did
iskidoo
Silver - Posts: 1,048
Posted: July 26, 2005 at 1:25 PM / IP Logged
What brand/model are you using? Are the relays external or built into the unit. If external, try swapping the accessory and ignition relays to at least get it running and to see if the ignition relay is bad.
Steve G
mrjc480
Member - Posts: 44
Posted: July 26, 2005 at 1:42 PM / IP Logged
it is a hornet 564t,  there is one sattelite relay that houses  constant, starter, ignition, second ignition, and accessory.  when i jump ignition to accessory or constant to accessory,  the engine doesnt not stay started,  only when i jump constant to ignition.
iskidoo
Posted: July 26, 2005 at 1:47 PM / IP Logged
Check for a negative output going to the satelitte for the ignition relay. Check the fuse supplying the satelitte relays. One may be fine and the other may be blown.
Steve G
mrjc480
Member - Posts: 44
Posted: July 27, 2005 at 9:50 PM / IP Logged
there is negative output going to the relay, i have 12+ coming out of the ignition lead, however it seems to drop to 10 volts during cranking.  when i cross the constant 12+ with the ignition lead the car will stay running.
mo12v
Posted: July 28, 2005 at 8:32 AM / IP Logged
Post  your Igntion wires you have connected...........
This is a Coupe DeVille?
MO
iskidoo
Posted: July 28, 2005 at 9:00 AM / IP Logged
Make sure the accessory relay output and the ignition output are not swapped because the accessory drops out during cranking which wouldn't allow it to start. Start it with the key and then activate the remote starter. Turn the key off...does the engine stay running?
Steve G
mrjc480
Member - Posts: 44
Posted: July 28, 2005 at 12:25 PM / IP Logged
the engine does stay running when i start with a key, then activate the remote start and remove the key.  off the relay i have...
(ignition) pink to vehicle pink
(accessory) orange to vehicle orange
(constant) both reds to vehicle red
ive also tried using the relays' 2nd ignition to vehicle ignition.  i am now just going to use a relay the to get 12+ from the constant and the trigger from the ignition.  let me know if this is a good idea or not.
mo12v
Posted: July 28, 2005 at 2:24 PM / IP Logged
On your FACTORY wires:
If you have a BROWN wire at Ignition Switch...that will be your ACCESSORY
The ORANGE wire at Ignition Switch should be treated as 2nd Ignition ( or should be powered while and after cranking )
MO
