viper compatibility
Steve23
Member - Posts: 43
Posted: July 30, 2005 at 8:37 PM / IP Logged
Hello all. I have a question in regards to the viper 771xv. The brain to the system is defective. I have a friend who has a brain to the 671 xv. Can I use that brain for my 771 system without problem?
Thanks alot in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: July 31, 2005 at 11:26 AM / IP Logged
check the wire pin posistions (color and location) Im not a viper guy.....so thats the best suggestion I can give ya!
Powermyster
Silver - Posts: 962
Posted: August 02, 2005 at 3:50 AM / IP Logged
run a search on here see if you can download the two manuals
swamprat323
Gold - Posts: 1,335
Posted: August 02, 2005 at 7:51 AM / IP Logged
Whst is worng with the 771.
Most the wiring is the same. only things different is the igntion input. on the 771 is with the relays fo rthe remote start, on the 671 its in the main harness, this be the yellow wire. which will NOT be on yours you have to add it.
Also the WHITE/ blue on the 771 is for remote start inside the car, on the 671 its for ch 3. if you did not have those hook up all you need to do is add a wire to the main harness for igntion.
