Horn honk issue with keyless entry
Sabbotage
Member - Posts: 10
Posted: August 02, 2005 at 7:43 PM / IP Logged
I just installed an Audiovox AA-925 keyless entry system in my 92 prelude and im having an issue with the horn honk when locking/unlocking the doors. When I first got everything wired up it all worked perfect and now when i lock or unlock the doors the horn wont chirp anymore like its supposed to, but it honks when i put the system into panic mode so i know the connection is good. I havent set any of the options yet so everything is at default and i even disconnected the battery overnight to clear the system out. I double checked the connections(soldered) and even looked at every option in the manual but i just cant get the horn to chirp anymore when i lock and unlock the doors. Does anyone have any input to this?
mo12v
Posted: August 02, 2005 at 8:29 PM / IP Logged
Doesn't the Audiovox AA-925  have a Silent Mode from the Remote?  Some of the units I have ( NOT Audiovox ) have a feature that can be programmed from Remote or Silent the Horn from the Remote
MO
