Is it hard to install a alarm?
Gr4v3_7
Member - Posts: 34
Posted: August 04, 2005 at 11:21 PM / IP Logged
I was wondering if it is very hard to install a alarm with remote start on my 1995 oldsmobile Cutlass Ciera.  People tell me that it is very hard but i would like to install it on my car. I do have experience installing cd players, speakers, and amps/subs.  When i buy the alarm, will it come with a step by step diagram on how to install it? Or will i have to figure it out on my own? Thanks for the feedback.
spider228
Member - Posts: 8
Posted: August 05, 2005 at 7:34 AM / IP Logged
When you buy the alarm u will get and  installation guide with it but if not you can find one online if you do a search.  When you do get an alarm/remote start you might want to get the vehicle wiring diagram from this site.  It is very helpful when installing remote start.  Its not that bad if you have patience. Ive installed many alarms/remote starts in many vehicles.  Just take your time and solder every connection so no problems will happen later down the road. Mount the sensors, brain, relays, ect... before you run the wires. It makes it alot esier to hide wires and make it look professional.
thepencil
Gold - Posts: 1,526
Posted: August 05, 2005 at 9:03 AM / IP Logged
You will have to do some homework, get your hands dirty and make that judgement for yourself. The differences between difficult and easy are just a matter of UNDERSTANDING. If you understand the concept and the fundamental of how an alarm unit operates I don’t see why it should be that hard to install.   Learn the basic and ask questions. Everything you need to know is all here on the forum. There are lots of professional installer here to help you out. Below is a wiring diagram for you vehicle. Take a look at it and hopefully you can put the two pictures together.
You can go here and download a copy of an alarm manual. They have the best installation manual for DIY and explain themselves very well.
DIRECTWIRE™ WIRING INFORMATION - OLDSMOBILE / CUTLASS CIERA / 1995 / Security
12volts red    +   ignition harness
Starter purple or yellow    +   ignition harness
Ignition pink    +   ignition harness
Power Lock lt. blue    +   near underdash light
Power Unlock white    +   in 3 and 8 pin plug
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ brown      steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger      -
Notes: Must go to each door to avoid dome light delay and/or alarm falsing from the dome light check circuit. For the drivers door, use Lt. GREEN/ black in the drivers kick panel. For the passenger door, use Lt. blue in the passenger kick panel. The rear doors have pin switches. Must go to each rear pin switch and diode isolate the factory wire a six amp diode. For rear door trigger attach between the diode and the pin switch. Each door trigger wire must be diode isolated to the alarm.
Dome Supervision
Trunk/Hatch Pin gray    -   rear dome lamp
Notes: Only available on the wagon models.
Hood Pin
Trunk/Hatch Release black    +   release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer      AC ignition coil module
Notes: Use white or orange on the 4 cylinder motor, and PURPLE / white on the 6 cylinder motor.
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
VATS
Part #: 652T resistor pack
Notes: See DirectFax document 1049 for interface information.
Be careful whose advice you buy, but be patient with those who supply it.Is it hard to install a alarm? -- posted image.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
