2005 Chevy Malibu, Avital 2100
esl install
Posted: August 15, 2005 at 8:38 AM / IP Logged
I'm installing the Avital 2100 in a 2005 Chevy Malibu.  I know that the disarm wire is purple and (-).  What do I do now to disarm the factory system.  Any help would be appreciated.
Moderator - Posts: 12,488
Posted: August 15, 2005 at 8:55 AM / IP Logged
Ground this to the chassis with a jumper wire. The Avital system doesn't have a disarm wire so you will not be able to use the OEM system along with the Avital system.
mo12v
Posted: August 15, 2005 at 9:06 AM / IP Logged
You could use Double Pulse for Disarm & Unlock, but if the Factory Alarm was triggered, alot of these Malibu's would NOT Disarm without using the Factory remote
OR
Use a DLM-3 from OMEGA....will Lock / Unlock & Disarm
MO
esl install
Posted: August 15, 2005 at 10:12 AM / IP Logged
Thanks, I really appreciate your help.
esl install
Posted: August 19, 2005 at 10:18 AM / IP Logged
need the wiring for a 2005 Chevy Malibu.  If possible also need the install instructions for a Avital 2100.  Tried Avitals site, but the istall section seemed to be down.  Any help would be appreciated.
thepencil
Gold - Posts: 1,526
Posted: August 19, 2005 at 10:39 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / MALIBU / 2005 / Remote Start
12volts RED / black (50A)   +   BCM, C3, pin D1
Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug.
Starter yellow (not for remote start)   -   PCM, blue plug, pin 48 or 23
Notes: Starter wire is not required for remote start. When the vehicle sees that the ignition wire has voltage and the accessory wire lose voltage, it automatically cranks the starter.
The PCM (Powertrain Control Module) is in front of the battery on the driver side fender.
Second Starter N/A
Ignition pink   +   ign harn or BCM, C4, pin D3
Second Ignition N/A
Third Ignition N/A
Accessory brown   +   ign harn or BCM, C4, pin C8
Second Accessory N/A
Keysense not required
Power Lock white   -   driver kick or BCM, C1, pin 66
Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1.5K ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor gray/black to gray   5wi driver kick or BCM, C3, pin A5
Unlock Motor tan   5wi driver kick or BCM, C3, pin B1
Parking Lights+ brown   +   driver kick or BCM, C3, pin A7
Parking Lights- BROWN / white   -   switch or BCM, C2, pin 5
Hazards white   -   switch or BCM, C2, pin 9
Turn Signal(L) dk. blue (F), yellow (R)   +   BCM, C1, pin 38 and C3, pin A9
Turn Signal(R) dk. green (F), dk. green (R)   +   BCM, C1, pin 56 and C3, pin A12
Reverse Light lt. green   +   fuse block, driver side of trunk
Door Trigger gray/black (D), tan/white (P)   -   each kick or BCM, C1, pins 51 and 72
Notes: Use both wires and diode isolate each.
Dome Supervision gray   -   BCM, C3, pin A10
Trunk/Hatch Pin ORANGE / black   -   BCM, C1, pin 18
Hood Pin pink/black   -   pin switch or BCM, C1, pin 69
Trunk/Hatch Release BROWN / white   -   switch or BCM, C1, pin 71
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm purple   -   driver kick, door harness
Notes: This wire will disarm the factory alarm if it has not been triggered, but might not disarm if it has.
This wire will also unlock the doors with a double pulse.
Disarm No Unlock with ignition and Passkey
Tachometer NOT pink   ac   any fuel injector
Wait to start N/A
Brake Wire white   +   BCM, C1, pin 42
Parking Brake lt. blue   -   switch or BCM, C1, pin 59
Horn Trigger tan   -   switch or BCM, C2, pin 14
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
Avital 2100
Be careful whose advice you buy, but be patient with those who supply it.2005 Chevy Malibu, Avital 2100 -- posted image.
Sunday, August 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
