2000 Cougar wiring diagram?
f02150
Posted: August 16, 2005 at 1:15 PM / IP Logged
Does anybody know where i can get the Wiring diagram for a 2000 Mercury Cougar. My sister has an alarm and she wants it installed, and i figured i would help her out to put it in. Now i know how to do all that stuff, but i don't know what wires are what exactly and don't want to take the risk of cutting or crimping something i don't know what it is. So if you guys could help me out on that, it would be much apprectiated, or at least put me in the right direction to do it correctly.
thepencil
Gold - Posts: 1,526
Posted: August 16, 2005 at 1:19 PM / IP Logged
MERCURY COUGAR 2000
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|gray/white          |+ |ignition harness            |
|        IGNITION|green               |+ |ignition harness            |
|        ACCESSORY|yellow              |+ |ignition harness            |
|       POWER LOCK|YELLOW /GREEN        |- |drivers kick panel          |
|     POWER UNLOCK|WHITE/ green        |- |drivers kick panel          |
|       LOCK MOTOR|yellow/black        |   |drivers door harness        |
|     UNLOCK MOTOR|WHITE/ black        |   |drivers door harness        |
|    DISARM DEFEAT|WHITE/ green        |   |passenger door harness      |
| PARKING LIGHTS +|RED / blu & RED / yel *5|   |headlight switch            |
| PARKING LIGHTS -|BLACK / YELLOW        |   |keyless module *1           |
|     DOOR TRIGGER|blk/red & blk/grn *2|- |top of the fuse box        |
| DOME SUPERVISION|BLACK/ blue          |- |drivers 'A' pillar          |
| TRUNK/HATCH PIN|BLACK/ orange        |- |drivers running board *3    |
|TRNK/HTCH RELEASE|BLACK / YELLOW        |- |at switch or drivers kick   |
|FCTRY ALRM DISARM|BLACK/ white        |- |drivers kick panel          |
|       TACHOMETER|BROWN / green        |   |ignition coil pack          |
|      SPEED SENSE|WHITE/ blue          |   |*4                          |
|       BRAKE WIRE|ORANGE / blue        |+ |brake switch               |
|     HORN TRIGGER|BLACK/ blue          |- |ignition harness            |
| LF WINDOW UP/DN|wht/pur - yel/pur   |A |drivers door switch        |
| RF WINDOW UP/DN|white - yel/grn     |A |drivers door switch        |
Notes:
NOTE: This vehicle is equipped with PATS (Passive Anti Theft System). Use DEI module 555F to over-ride during remote start. *1 The keyless module is located behind the glove box. This wire flashes the hazard lights. *2 Use BLACK/ red for the drivers door and BLACK/ green for the passengers door. Diode isolate each wire together to the alarm. To access these wires, pull fuse panel down and remove cover.   *3 Towards the rear of the running board. *4 Located between the firewall and the strut tower on the drivers side of the motor in a 10 pin connector. *5 These wires must be relay isolated from the headlight switch to keep the headlights from flashing with the parking lights.
Be careful whose advice you buy, but be patient with those who supply it.2000 Cougar wiring diagram? -- posted image.
f02150
Posted: August 16, 2005 at 1:25 PM / IP Logged
Thepencil,
that was some fast response time there. Now from what it says there, that is where i can find the wire correct?
And if you could i have an alarm i want to put in my Acura RSX 2005, and i would like a diagram for it also if possible? I already have a DIY for a Compustar alarm, which i could go off of and use the same wires, but i was wondering if i could get that diagram just incase, if that is possible.
And just for future reference, where are you getting those diagrams from, or where could i go to get them, to be curiuos?
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
