access to toyota wirng diagram
robHI
Member - Posts: 35
Posted: December 02, 2002 at 6:09 PM / IP Logged
anyone can provide wiring diagram to a 98 toyota avalon and a 99 toyota carmy???
stevembud
Posted: December 02, 2002 at 8:23 PM / IP Logged
NEED TO COMPARE A 89 TOYOTA PICK UP TO A 96 T100 WIRING DIAGRAM
tskm
Platinum - Posts: 12,488
Posted: December 03, 2002 at 1:12 AM / IP Logged
1989 PICK UP:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white - WHITE/ red   |+  |ignition harness            |
|          STARTER|black               |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|blk/yel or blk/red  |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|blue/white          |-  |door control relay *2       |
|     POWER UNLOCK|blue / YELLOW         |-  |door control relay *2       |
| PARKING LIGHTS +|green               |   |drivers kick panel *3       |
| PARKING LIGHTS -|RED / black           |   |steering column             |
|       HEADLIGHTS|RED / white           |-  |steering column             |
|     DOOR TRIGGER|BLACK/ white or black|-  |2 pin plug top fusebox      |
|       TACHOMETER|black               |   |check connector *1          |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|blue/black          |+  |steering column             |
|  LF WINDOW UP/DN|blu/grn - blu/yel   |A  |in drivers door             |
|  RF WINDOW UP/DN|blu/blk - RED / grn   |A  |in drivers door or dkp      |
Notes:*1 The diagnosis connector is located on the passenger inner fender near the fuse/relay box. *2 Door control relay is located behind the driver dash speaker. *3 Can also be found at any illuminated switches, radio, or some cigarette lighters.
1996 T100
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|       POWER LOCK|RED / wht or blu/wht  |-  |low in driver kick panel *2 |
|     POWER UNLOCK|RED / yellow          |-  |low in driver kick panel *2 |
| PARKING LIGHTS +|green               |   |at fusebox                  |
|     DOOR TRIGGER|BLACK/ white         |-  |wht plug in fusebox         |
|       TACHOMETER|black               |   |igniter, check conn *1      |
|      SPEED SENSE|green               |4  |ECM behind glove box        |
|       BRAKE WIRE|GREEN / WHITE         |+  |drivers kick panel          |
|           WIPERS|blu/blk, yel/blk *3 |+  |steering column             |
|  LF WINDOW UP/DN|blu/yel - blu/grn   |A  |in drivers door             |
|  RF WINDOW UP/DN|RED / blk - RED / grn   |A  |in drivers door             |
Notes:*1 The check connector is located on the front passenger inner fender well next to the underhood fuse box. *2 Lock relays located in driver's kick panel. Test with doors closed, or both pin switches held in. *3 Catch both wires and diode isolate.
Saturday, January 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
