2005 nissan titan, autopage 855
toddamcdougal
Posted: August 25, 2005 at 12:46 PM / IP Logged
wanting to put a autopage 855 with remote start, have front window operation and controll sliding rear window. please help wirh wiring diagrams. and any relays and modules local install shop scared of titan
iskidoo
Silver - Posts: 1,048
Posted: August 25, 2005 at 12:50 PM / IP Logged
http://directechs.com/directwire/wire_body.asp?action=select&yr=5993&product=Remote%20Start
NOTES
NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold.
http://64.85.6.129/extrainfo/diagrams/26500_TITAN_(-)%20NEGATIVE%20DOOR%20PIN%20ISOLATION%20CIRCUIT.pdf
Steve G
