2000 dodge dakota
Welcome Guest :)
pacheco_2000
Member -
Posted: December 04, 2002 at 12:23 PM / IP Logged
please I need a wiring diagrams for installing a remote started as well as for my 1996 dodge neon and i have a question why when i printed the 00 dodge dakota wire diagram from the web 12v i get two different ones.
carlospacheco
Platinum -
Posted: December 04, 2002 at 12:40 PM / IP Logged
Here is what i have for the following vehicles:
2000 Ddge Dakota:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red or pink/black |+ |ignition harness || STARTER|blue / YELLOW |+ |ignition harness || IGNITION|dark blue |+ |ignition harness || SECOND IGNITION|BLACK/ orange |+ |ignition harness || THIRD IGNITION|GREEN/ red |+ |ignition harness || ACCESSORY|BLACK/ white |+ |ignition harness || POWER LOCK|org/pur or grn/blk |+ |drivers kick panel || POWER UNLOCK|pink/purple *2 |+ |drivers kick panel || PARKING LIGHTS +|BLACK / YELLOW | |behind fuse box || PARKING LIGHTS -| | | || HEADLIGHTS|light green |- |steering column || DOOR TRIGGER|yellow |- |behind fuse box || TRUNK/HATCH PIN| | | || HOOD PIN| | | ||TRNK/HTCH RELEASE| | | || FCTRY ALARM ARM|*1 | |drivers door harness ||FCTRY ALRM DISARM|*1 | |drivers door harness || TACHOMETER|blk/gry or gry/blk | |coil pass. sid of eng. || BRAKE WIRE|WHITE/ tan |+ |at brake switch || HORN TRIGGER|BLACK/ red |- |steering column || WIPERS|RED / yellow |+ |wiper switch || LF WINDOW UP/DN|lt. blue - white |A |drivers door switch || RF WINDOW UP/DN|brn/wht - ppl/wht |A |drivers kick panel || LR WINDOW UP/DN| | | || RR WINDOW UP/DN| | | |Notes:
*1 Must use relays and set up for (-) negative trigger. Place a 600 ohm resistor to the lt.GREEN/ orange for arm, and a 1300 ohm resistor on the same wire for disarm. This wire will also lock the doors, and it will unlock with a double pulse. *2 Vehicles with keyless entry, have to 5 wire the unlock wire.1996 Dodge Neon
| 12V|red & pink/black |+ |ignition harness *1 || STARTER|yellow |+ |ignition harness *1 || IGNITION|dk. blue |+ |ignition harness *1 || ACCESSORY|BLACK/ orange |+ |ignition harness *1 || POWER LOCK|ORANGE / purple |5wi|taped harness from driv door|| POWER UNLOCK|pink/purple |5wi|taped harness from driv door|| LOCK MOTOR|ORANGE / black | |drivers kick || UNLOCK MOTOR|pnk/wht or pnk/blk | |drivers kick || DISARM DEFEAT|pink/black | |passenger kick || PARKING LIGHTS +|BLACK / YELLOW | |at headlight switch || PARKING LIGHTS -| | | || HEADLIGHTS|lt. green |+ |at headlight switch || DOOR TRIGGER|yellow/black |- |behind headlight swtch || TRUNK/HATCH PIN|gray/black |- |at light in trunk || TACHOMETER|tan/blu or blk/gry | |top motor 3 pin plug || BRAKE WIRE|WHITE/ gold dots |+ |at brake switch || HORN TRIGGER|BLACK/ red |- |steering column || WIPERS|grn/yel, RED / yel |+ |steering column *2 || LF WINDOW UP/DN| | | || RF WINDOW UP/DN| | | || LR WINDOW UP/DN| | | || RR WINDOW UP/DN| | | |Notes:
*1 SRS airbag wires are not enclosed in sheath at the steering column. They are a twisted pair run with rest of ignition harness. Be careful not to cut or probe these wires. *2 Combine with diodes to get all speeds.Jeff
Wednesday, March 18, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
