Relay for Engine cut off
pbaronmk1cab
Posted: September 10, 2005 at 11:48 AM / IP Logged
can anyone help with connecting the relay as in the image below.
THe relay has the following wires from the pins
87 -no wire
87a green
85 yellow (with diode connecting to 86)
86 white (with diode connecting to 85)
30 green
Just a bit unsure to which wire connects to what
pbaronmk1cab
Posted: September 10, 2005 at 1:04 PM / IP Logged
I have uploaded an image of the relay and wiring but for some reason it isnt showing ???
mo12v
Posted: September 10, 2005 at 1:42 PM / IP Logged
SPDT Relay
1 or 2 amp Diode across PIN 86 & PIN 85 with stripe facing PIN 86
Cut Starter wire in half:
PIN 86 & 30  = Ignition switch half of cut wire
PIN 87a  = Starter side of cut wire
PIN 85 = Negative Output from Alarm while Armed
MO
